無法上傳 MODEL 至 kl520
上傳模型時遇到此問題,使用預設範例就會出現這個問題,520 使用 usb 加速棒
[Connect Device]
- Success
[Set Device Timeout]
- Success
[Upload Firmware]
- Success
[Upload Model]
Error: upload model failed, error = 'Error raised in function: get_model_info. Error code: 10. Description: ApiReturnCode.KP_ERROR_DEVICE_NOT_EXIST_10'
Command 資訊:
[Check Device]
- success
[Connect Device]
- target device: 'KL520'
- scan index: '0'
- port ID: '17'
- command: 'system'
[System Information]
"kn_number": "0xBE0A170C",
"firmware_version": "2.0.0-build.706"
[PLUS Version]
2.0.0
Hi Johnson,
可以跟您請教一下您的OS版本嗎 (Windows, Linux, etc.)? 還有,您的KL520的USB加速棒是如何與您的電腦連接的呢? 您的電腦現在有連接著很多其他的東西嗎?
因為load model時會再次與KL520加速棒連接,這時如果連接速度太慢,有可能會造成這個error。
P.S. 請問一下,您有修改範例程式或模型嗎? 如果有的話,麻煩您提供程式給我們作為參考,謝謝!
還有,可以請您提供ScanDevices.py的結果嗎? 我們會需要確認device boot-mode。
Hi @Maria Chen 感謝你的回應
可以跟您請教一下您的OS版本嗎 (Windows, Linux, etc.)? Windows 11 之前都可以用
只有接著 520 與 Webcam
ScanDevices.py
scanning kneron devices ...
number of Kneron devices found: 1
listing devices infomation as follows:
[0] USB scan index: '0'
[0] USB port ID: '9'
[0] Product ID: '0x100 (KL520)'
[0] USB link speed: '3'
[0] USB port path: '1-2'
[0] KN number: '0xBE0A170C'
[0] Connectable: 'True'
[0] Firmware: 'KDP2 Comp / U'
""" check device USB speed (Recommend run KL520 at high speed) """ try: if kp.UsbSpeed.KP_USB_SPEED_HIGH != get_device_usb_speed_by_port_id(usb_port_id=usb_port_id): print('\033[91m' + '[Error] Device is not run at high speed.' + '\033[0m') exit(0) except Exception as exception: print('Error: check device USB speed fail, port ID = \'{}\', error msg: [{}]'.format(usb_port_id, str(exception))) exit(0) """ connect the device """ try: print('[Connect Device]') device_group = kp.core.connect_devices(usb_port_ids=[usb_port_id]) print(' - Success') except kp.ApiKPException as exception: print('Error: connect device fail, port ID = \'{}\', error msg: [{}]'.format(usb_port_id, str(exception))) exit(0) """ setting timeout of the usb communication with the device """ print('[Set Device Timeout]') kp.core.set_timeout(device_group=device_group, milliseconds=10000) print(' - Success') """ upload firmware to device """ try: print('[Upload Firmware]') kp.core.load_firmware_from_file(device_group=device_group, scpu_fw_path=SCPU_FW_PATH, ncpu_fw_path=NCPU_FW_PATH) print(' - Success') except kp.ApiKPException as exception: print('Error: upload firmware failed, error = \'{}\''.format(str(exception))) exit(0) """ upload model to device """ try: print('[Upload Model]') # model_nef_descriptor = kp.core.load_model_from_file(device_group=device_group, # file_path=MODEL_FILE_PATH) model_nef_descriptor = kp.core.get_model_info(device_group=device_group, usb_port_id=usb_port_id) print(' - Success') print('[Model NEF Information]') # print(model_nef_descriptor) except kp.ApiKPException as exception: print('Error: upload model failed, error = \'{}\''.format(str(exception))) exit(0) 在這就出現問題無法往下了 """ prepare generic image inference input descriptor """ _generic_inference_input_descriptor = kp.GenericImageInferenceDescriptor( model_id=model_nef_descriptor.models[0].id, inference_number=0, ) 下略Hi Johnson,
謝謝您提供的資訊! 我們看了您提供的程式。
在KL520上,需要先跑load_model_from_file (下面被註解掉的地方),才能跑get_model_info,因為usb-boot upload fw會洗掉DDR上的所有資料(包含模型)。
還有,usb_port_id需要確認是否有給,如果給0 (預設)的話,會找不到device。您之前跑ScanDevices.py的結果,port ID是9 (之前是17?),所以可以設定usb_port_id=9或17,請參考ScanDevices.py的USB port ID。
@Maria Chen 感謝您的回應,這行應該是之前測試誤刪了,目前已加回
