yolov7-tiny轉檔問題請教
嗨,目前嘗試將yolov7-tiny的模型轉當成NEF檔,並燒錄到KL630的開發板上。
以下是我的流程:
1..pt -> .onnx
(使用yolov7官方的export.py)
python export.py --weights yolov7-tiny.pt --grid --end2end --simplify --topk-all 100 --iou-thres 0.65 --conf-thres 0.35 --img-size 640 640 --max-wh 640
2..onnx -> sim.onnx
onnxsim yolov7-tiny.onnx yolov7-tiny_sim.onnx
3. sim.onnx -> sim_convert.onnx
python ONNX_Convertor/optimizer_scripts/onnx2onnx.py yolov7-tiny_sim.onnx -o yolov7-tiny_sim_convert.onnx
INFO:optimizer_scripts:Preprocessing the model...
WARNING:optimizer_scripts:The following operatos are currently not well supported by our toolchain: {'ArgMax'}
(op_type:Concat, name:Concat_312): Inferred shape and existing shape differ in dimension 0: (1) vs (21)
File "ONNX_Convertor/optimizer_scripts/onnx2onnx.py", line 155, in <module>
duplicate_shared_weights=args.duplicate_shared_weights)
File "ONNX_Convertor/optimizer_scripts/onnx2onnx.py", line 46, in onnx2onnx_flow
m = combo.preprocess(m, disable_fuse_bn, duplicate_shared_weights)
File "/data/NAS/ComputeServer/ytl0623/ai_training/detection/yolov5/yolov5/ONNX_Convertor/optimizer_scripts/tools/combo.py", line 73, in preprocess
model_proto = onnx.utils.polish_model(model_proto)
File "/home/ytl0623/data/anaconda3/envs/yolov5-py3.7/lib/python3.7/site-packages/onnx/utils.py", line 20, in polish_model
model = onnx.shape_inference.infer_shapes(model)
File "/home/ytl0623/data/anaconda3/envs/yolov5-py3.7/lib/python3.7/site-packages/onnx/shape_inference.py", line 35, in infer_shapes
inferred_model_str = C.infer_shapes(model_str, check_type)
RuntimeError: Inferred shape and existing shape differ in dimension 0: (1) vs (21)
想請問以上轉檔流程是否有誤,另外error的原因猜測是有不支援的opearator,我應該如何解決?
以上問題請教,感謝。
看訊息中有提到ArgMax,推測是模型中含有這個不支援的operator所造成
argmax是基於多個機率取最大值的運算,一般來說我們會放在後處理中再執行,所以要請你將onnx模型的最末端做調整,我們自己內部會是到Sigmoid的地方做結尾,剩餘的移到後處理來執行
有關yolov7的相關修改,也可以參考我們提供的修改說明
https://www.kneron.com/tw/support/developers/?folder=Documentation%20center/&download=1904
Hi, 感謝回覆,想請問一下
1. -0.5~0.5 是因為要轉換成 int8 的原因嗎?
2. 請問投影片最後一張是指 models/yolo.py 這個檔案嗎? 另外,是要把原本的 forward function 更改成 modify版本嗎? (但我看行數對不太起來)
以上問題請教,感謝。
有關您的問題如下
