kp_firmware_host_stream build file problems
I follow instruction below
and Compile in solution host_stream with path:
KLM5S3-V2.5.5/SDK/Software_Toolkit/sdk_v2.5.5/sdk/apps/vmf_nnm/solution/solution_host_stream
and
and Copy files ( kp_firmware_host_stream and my nef (models_630_3dcnn.nef) ) in Path:
KLM5S3-V2.5.5/SDK/Software_Toolkit/sdk_v2.5.5/sdk/apps/vmf_nnm/bin/kp_firmware/bin
to KL630.
Moreover, I modified Model_path, Model_Id, JobId, ImageWidth, ImageHeight, Fps in host_stream.ini (KL630 board)
However, I got following error when I run firmware in KL630.
Even though I built the kp_firmware_host_stream , I think it's strange that the image size is 2560x1920 instead of 1920x1080, and the built file doesn't seem to have been applied. I'd like to ask if there's something I did wrong.
  • Hi YOUNGJUN,
    According to the information you provided, please note the following points:
    1. Model IDs must be larger than 32767.
    2. The KL630 program is experiencing repeated execution. It automatically runs rc.local at startup. Renaming rc.local will prevent it from executing automatically.
    3. "ImageWidth: 2560 ImageHeight: 1920" This is the resolution of the stream to the NPU based on the settings in "host_stream.ini".
    host_stream.ini
    [nnm]
    InferenceStream = 1         # Inference stream index
    [stream1]
    Codec = 0                   .#VMF_VENC_CODEC_TYPE_H264
    Width = 1280                #The image width of stream0
    Height = 960                #The image height of stream0
  • Thank you Nick,
    1.Model IDs must be larger than 32767. I changed the model id = 35000 for nef generation and successfully converted to nef. with following code
    - km = ktc.ModelConfig(35000,"0001","630", onnx_path="optimized_3dcnn.onnx"
    and build it with changing the my_kl630_sin_example_inf.h (Path: KLM5S3-V2.5.5/SDK/Software_Toolkit/sdk_v2.5.5/sdk/apps/vmf_nnm/solution/solution_host_stream/include)
    and copy kp_firmware_host_stream (Path: KLM5S3-V2.5.5/SDK/Software_Toolkit/sdk_v2.5.5/sdk/apps/vmf_nnm/bin/kp_firmware/bin)
    to KL630 board.
    But I have following error
    3."ImageWidth: 2560 ImageHeight: 1920" This is the resolution of the stream to the NPU based on the settings in "host_stream.ini".
    (Path: mnt/flash/vienna/ini/host_stream.ini in KL630 board)
    I also, chagned the host_stream.ini like this picture
    the "ImageWidth: 2560 ImageHeight: 1920 are not changed.
    I think I have modified wrong file or followed wrong processes, could you give me way to solve these problems?
  • Hi YOUNGJUN,
    I noticed that your KL630 firmware is old, please download the v2.5.5 version from our website.
    https://www.kneron.com/tw/support/developers/
    "KL630_96board_firmware_for_kneron_plus_sdk2.5.5.zip" is for companion mode, you can also verify the model with this mode first.
    Also, according to the error log you provided, the program is still running repeatedly. Please confirm rc.loacl again.
  • Hi YOUNGJUN,
    As a reminder, our recommended verification model process is as follows :
    1. Verify the E2E simulation of NEF on the toolchain docker.
    2. Confirm the results of KL630 companion mode.(python code)
    3. Confirm the results of KL630 companion mode.(C code)
    4. Move C code to KL630.
  • Dear Nick Wang,
    I think Process 1 is done.
    But, I'd like to check that following link is Process 2, 3, right?
    My model is custom model (video classification). Do I have to proceed building my model with companion mode? Could you explain about what is companion mode (KL630) ?
  • I tried to proceed
    So, I connected KL630 via usb and
    refer Chapter 1.9 of the KL630_96board_User_Manual.
    But, I can't find KL630 board with following error (putty)
    and I also cannot find the device in DFUT KL 630
    Please help me.
  • Hi YOUNGJUN,
    Please provide me with the log from when the KL630 is turned on to when you run plus_usb_companion_init.sh and I will help you check if there are any problems.
