Toolchain V0.25.0 Problem
We are testing a model on both toolchain v0.24.0 and v0.25.0. When we are using the same code to convert models, there are lots of errors on 0.25.0. All of them could be solved by either changing 720 to "720" or add str() to the platform variable. I think this has nothing to do with my code. Maybe your codebase still needs improvements to make it compatible with string and int type of 720. The errors look like below:
    Thanks for feedback.
    We did find some issues with the latest version 0.25.0 and are currently addressing them. Please hold on and wait for the next version.
  • @JIN QIAN
    Hi JIN QIAN,
    There is now a v0.25.0_3 for v0.25.0 Kneron Toolchain hot fix version, you can try it.
    If you still encounter bugs, please provide us with the scripts, and provide us with the things we need to run the scripts.
