KL520 datasheet and hardware design guide
How to get KL520 datasheet?
And, If any hardware design guide or application note is available?
Hi
Please check our development center to see if you can find them.
Thanks,
Hi Eddie,
if you wish to use two PMU, one of them should be RTC power and the other should be the rest of the power needed in KL520.
In this case, you have two power mode, RTC mode and full function mode.
