Run ML Models parallel in npu
Is there a way to run ml models run parallely in npu
  • Hi Sathish,
    Unfortunately, we can't run models parallely in NPU, but if you were in companion mode and used 2 dongles, it could perform nearly as close as running parallely.
  • edited May 28
    Thanks a lot for the info
