Different detection result with different user_id in kl720_dme_serial_yolo.cpp
project source: host_lib_v0.9.1.zip in kneron developer
File: kl720_dme_serial_yolo.cpp file
Input image and model are all as same as original source.(a_dog_640x480_rgb565.bin / yolov3_tiny_416)
I only change user_id to check 2 different detection result.
If user_id is 1:
else:
left top coordinate, bounding box size and confidence are all not same.
What causes the difference?
Hello, DME mode 在目前的版本需要要修正.
建議使用 ISI 的版本
