python3 main.py -t KL520-cam_isi_async_yolo return -1
Hi
i have complete below steps:
owen@owen-Aspire-3830TG:~/host_lib_v1.0.0/python$ python3 main.py -t KL520-update_app_nef_model
adding devices....
start kdp host lib....
Task: KL520-update_app_nef_model
Start updating fw...
Update SCPU firmware succeeded...
Update NCPU firmware succeeded...
Start updating model...
Update model succeeded...
Start reporting sys status...
Report sys status succeeded...
FW firmware_id 1.5.0.0, build_id 113
de init kdp host lib....
and want to do "KL520-cam_isi_async_yolo" based on README but got problem:
1. From the chart, we know we need to use model `tiny_yolo_v3`.
2. Copy all files (`*.bin`) under `input_models/KL520/tiny_yolo_v3` into `app_binaries/KL520/ota/ready_to_load`.
Q: there are no bin? only models_520.nef, where is the bin file?
what i did is below:
$ cp ../app_binaries/KL520/ssd_fd_lm/fw_* ../app_binaries/KL520/ota/ready_to_load/
$ cp ../input_models/KL520/tiny_yolo_v3/models_520.nef ../app_binaries/KL520/ota/ready_to_load/
3. Enter `python` directory.
4. Run `python main.py -t KL520-update_app_nef_model` (This step may take some time).
5. Run `python main.py -t KL520-cam_isi_async_yolo`.
also got error in "5":
owen@owen-Aspire-3830TG:~/host_lib_v1.0.0/python$ python3 main.py -t KL520-cam_isi_async_yolo
adding devices....
Task: KL520-cam_isi_async_yolo
Starting ISI mode...
Could not set to ISI mode: -1...
could you help provide some comment? thanks.
  • In ISI mode, KL520 will load firmware and model from flash. So you must update fw and model before ISI inference.
    For example yolo, you can find firmware files in /app_binaries/KL520/tiny_yolo_v3/ and model in /input_models/KL520/tiny_yolo_v3/models_520.nef
    I think the error you encountered is caused by wrong firmware (ssd_fd_lm), please update all of the files for yolo and try again.
  • thanks! it is ok now!
