How to accurately set the `ModelId` in host_stream.ini?
Hi, I tried to run host_stream app (kp_firmware_host_stream) on the KL630 board.
With a custom model trained by myself, I set them ModelPath with a specific path in the host_stream.ini.
ModelPath = "nef/models_630_xxx.nef")
But I have no idea about how to accurately set the ModelId ?
ModelId = ???
Or anything I have to edit before running it successfully?
Thanks in advance!
Please refer to this document for Model ID settings.
https://doc.kneron.com/docs/#toolchain/appendix/toolchain_webgui/
Thank you!
Problem Solved!
Thank you very much! 🙏
