KL630 inference error
I use KL630 board to infererence following custom nef file. (3DCNN model)
(path: /vmf_nnm/solution/app_flow/
But, when I run code I failed to inference with input following function (VMF_NNM_Inference_App_Execute)
int result = VMF_NNM_Inference_App_Execute(&inf_config);
with code 110 (int result).
How can I solve it?
code
static int inference_video_classification(my_kl630_sin_example_header_t *_input_header,
struct Video_classification_result_s *_3DCNN_result /* output */,
kp_app_pd_class_t *pd_class /* output */)
//printf("Check_ERROR 1 \n");
// Config image preprocessing and model settings
VMF_NNM_INFERENCE_APP_CONFIG_T inf_config;
memset(&inf_config, 0, sizeof(VMF_NNM_INFERENCE_APP_CONFIG_T)); // For safety let default 'bool' to 'false'
// Image buffer address should be just after the header
inf_config.num_image = 15; // For 15fps
inf_config.image_list[0].image_buf = (void *)((uint32_t)_input_header + sizeof(my_kl630_sin_example_header_t));
inf_config.image_list[0].image_width = _input_header->width;
inf_config.image_list[0].image_height = _input_header->height;
inf_config.image_list[0].image_channel = 3;
//inf_config.image_list[0].image_format = KP_IMAGE_FORMAT_RGB565; // Assume RGB565
inf_config.image_list[0].image_format = KP_IMAGE_FORMAT_YUV420; // Assume yuv420
inf_config.image_list[0].image_norm = KP_NORMALIZE_KNERON; // This depends on model
inf_config.image_list[0].image_resize = KP_RESIZE_ENABLE; // Default: enable resize
inf_config.image_list[0].image_padding = KP_PADDING_DISABLE; // Default: disable padding
inf_config.model_id = MODELS_630_3DCNN; // This depends on model
printf("Inference Configuration: Image Width: %d, Height: %d\n", _input_header->width, _input_header->height);
// Set up fd result output buffer for ncpu/npu
inf_config.ncpu_result_buf = (void *)_classifier_result;
// Debugging: Model ID and Output Buffer
printf("Model ID: %d, Output Buffer: %p\n", inf_config.model_id, inf_config.ncpu_result_buf);
inf_config.post_proc_func = classifier_post_process;
// Debugging: Output buffer address 확인
printf("Output Buffer Address: %p\n", (void *)inf_config.ncpu_result_buf);
printf("Check_ERROR 2 \n");
if (inf_config.ncpu_result_buf == NULL) {
printf("Error: Output buffer is NULL after allocation!\n");
printf("Check_ERROR 2.1 \n");
// Debugging: About to execute inference with the current model ID
printf("About to execute inference with model ID: %d\n", inf_config.model_id);
// Execute the inference
int result = VMF_NNM_Inference_App_Execute(&inf_config); //ERROR with result=110
printf("Check_ERROR 2.2 \n");
// Debugging print to check after inference execution
printf("After inference execution: Result: %d\n", result);
if (result != KP_SUCCESS) {
printf("Inference failed with result code: %d\n", result);
// Check if inference was successful and set the classification result
if (result == KP_SUCCESS && _3DCNN_result != NULL && _3DCNN_result->class_score != NULL) {
// Check the score array's first element and map it to kp_app_pd_class_t
//int class_PROC = _3DCNN_result->Video_classification_result.class_ID[0]; // 첫 번째 class 만 사용한다고 가정
int class_PROC = 0;
float class_Prob = _3DCNN_result->score[0]; // 첫 번째 스코어 값만 사용한다고 가정
//YJ 240912 추가 - 향후 테스트 필요
int max_Prob_idx = find_max_score_index(_3DCNN_result); // max_Prob_idx를 찾아줌
int class_PROC = _3DCNN_result->class_ID[max_Prob_idx]; // 해당 idx 사용한다고 가정
//int class_PROC = 0;
float class_Prob = _3DCNN_result->class_score[max_Prob_idx]; // 해당 idx 사용한다고 가정
// Debugging print to check the result and first score value
printf("Class Result: %d, Prob Score: %f\n", class_PROC , class_Prob );
*pd_class = class_PROC;
else {
printf("Inference execution failed or result is invalid.\n");
result = KP_FW_DDR_MALLOC_FAILED_102; // 적절한 에러 코드 반환
// 디버깅: 추론 결과를 반환하기 전에 결과 값 확인
// result: 추론 상태에 대한 상태
// pd_class: 몇번째 class 인지
printf("Final Result: %d, Mapped Class: %d\n", result, *pd_class);
return result;
The error code 110 seems to be caused by wrong input buffer count. Before porting your model directly on KL630, please check this link: How to save the streamd camera image in KL630 in ther board ? — Kneron Developer Forums
