Inquiry on Implementing Real-Time Classification with Kneron 630 and Python
Hello. I'm a developer working with the Kneron 630.
I'm encountering difficulties in development using Kneron plus Python.
What I'm trying to do is receive input from a camera sensor, pass it through NPU inference, and then retrieve the inferred value on Kneron plus.
The camera KL630 board application uses kp_firmware_hico_mipi.
I’ll share the necessary file contents. Below is the start.sh file:
#/bin/sh
mount -t configfs configfs /sys/kernel/config
mkdir -p /tmp/venc/c0/;
mkdir -p /tmp/aenc/c0/;
mkdir -p /tmp/playback/c0/;
mkdir -p /tmp/twoway/c0/;
mkdir -p /tmp/sr/c0/;
export LD_LIBRARY_PATH=$(pwd)/lib;
#./streamer_msg_sender -C 1 -s 0 -d 2 -q 10
./rtsps -c stream_server_config.ini &
#./kp_firmware_host_stream &
./kp_firmware_hico_mipi &
sleep 10;
./uvc_service &
### Notice : Codec type AAC4, sample rate 8000, bit rate 32000, raw format, stereo, mic_in ###
#./tinyaenc_mmap -d "hw:0,0" -r 8000 -C 0 -b 32000 -t 0 -S 0 -i 0 &
#sleep 2;
#./volume_ctrl -i 0 -M 0 -v 96;
#./playback_example_mmap -d "hw:0,0" -r 8000 -c 2 -C 0 &
Below is the driver.sh file.
I'm alternating between USB companion mode and UVC mode by commenting and uncommenting these four files: usb_f_uvc.ko, usb_f_uac.ko, g_webcam.ko, 8192eu.ko.
#!/bin/sh
insmod vpl_edmc.ko
insmod vpl_dmac.ko
insmod vma_ifpe.ko
insmod vma_jdbe.ko
insmod vma_jebe.ko
insmod vma_ispe.ko
insmod vma_h4cde.ko
insmod vma_meae.ko
insmod vma_rs.ko
insmod vma_dce.ko
#insmod vpl_voc.ko
#insmod tp2912FA.ko
#insmod tp2912FB.ko
#echo 1920x1080 > /sys/class/vpl_voc/curt_mode
#insmod phy-vatics-usb.ko #Built-in
#insmod dwc2.ko #Built-in
#insmod libcomposite.ko #Built-in
insmod usb_f_uvc.ko
insmod usb_f_uac.ko
insmod g_webcam.ko
insmod 8192eu.ko
#insmod usb_f_mass_storage.ko #USB Storage mode
#insmod g_mass_storage.ko file=/tmp removable=1 #USB Storage mode
sh ./vma_h5cde.sh
sh sensor.sh
Ultimately, I want to implement a model that uses the KL630 for real-time classification and sends the results to a host PC.
Thank you in advance for your help.
For instructions on using hico_cam, please refer to the following steps:
Additionally, if you want to port a customized model to the KL630, please follow the steps below to verify that the model conversion is accurate at each stage.
ref: https://doc.kneron.com/docs/#toolchain/manual_1_overview/
