Yolov8 output Data dumping in KL630
I am currently using a KL630 board and running my YOLOv8 model. While I am able to see the output in the terminal, I'm facing an issue when trying to dump the output to a file. The file size is only 188 KB, whereas the actual output data size is around 6 MB.
I've been stuck with this problem for the past week and have tried multiple approaches to fix it, but nothing has worked so far. I'm wondering if anyone has encountered a similar issue or if there are any known memory restrictions or limitations on the KL630 board that could be causing this problem.
Any suggestions on how I can successfully dump the full output data to a file would be greatly appreciated!
Thanks in advance for your help!
  • Hi Jyoti,
    If you were talking about how in Kneron PLUS Python, the numpy arrays get truncated when you print out the results, you could try using:
    import sys
    import numpy
    numpy.set_printoptions(threshold=sys.maxsize)
    This would help print out all the results.
    If this wasn't the issue you're facing, could you explain more about it? Thanks!
  • Thank you I resolve the dumping issues.
    Currently I am working on post processing part. I am not getting any reference for kl630 if anyone knows please help me out.
    Thank you in advance.
  • Hi Jyoti,
    Usually, those who port their models would write their own postprocess, as they are the most familiar with their model. There are example tiny yolov3 and yolov5 postprocess functions in kneron_plus/python/example/utils, and for further technical assistance, please contact your sales representative, who would be the person you purchased your KL630 board from. Thank you!
