KL630 EVK 執行 Generic Image Inference的錯誤訊息
您好,我在KL630_V01 96board上用 windows PC 上面執行 ./kl630_demo_generic_image_inference_post_yolo
請問何種原因出現以下錯誤訊息,謝謝:
$ ./kl630_demo_generic_image_inference_post_yolo
connect device ... OK
upload firmware ... OK
upload model ... OK
read image ... OK
starting inference loop 10 times:
inference failed, error = -7 (USB: Operation timed out)
另外在telnet連線上也會看到以下訊息
[_get_model_info] get model info send fw_info response failed, sts 0
[kdp2_usb_companion_image_thread] error !! inf image size (739468) is bigger than buffer size (20480)
  • Hi RayYu,
    請問您有做了哪些改動呢?
  • 收到Kneron 的96 board(KL630_V01_20230313)之後就按照KL630 96board User Manual以及Getting started的流程來操作(https://doc.kneron.com/docs/#plus_c/getting_started/),簡列操作流程如下供參考:
    1.power on reset 96board
    2.telnet 192.168.3.10
    3. switch to Kneron PLUS(companion)
    4.用Kneron DFUT update to "USB boot " and RUN
    5.在windows 打開MYSYS2上執行./kl630_demo_generic_image_inference_post_yolo
  • Hi RayYu,
    請問您PLUS是使用哪個版本呢?
    也請幫忙提供KL630這端完整的log做查看,感謝!
  • Hi Nick,
    您好,Kneron PLUS用的是kneron_plus_v3.1.1, 在windows上編譯用General example時 cmake 4.0.0(自動安裝)
    另外後續更新了96 board firmware SDK 2.5.5後,error code 卻變成102
    執行時的LOG如下(MYSYS2+ Telnet (CMD prompt)):
    renyu@user MINGW64 /e/Prolific_2025/Kneron_tmp/kneron_plus/build/bin
    $ ./scan_devices.exe
    scanning kneron devices ...
    number of Kneron devices found: 1
    listing devices infomation as follows:
    [0] scan_index: '0'
    [0] port ID: '526'
    [0] product_id: '0x630' (KL630)
    [0] USB link speed: 'High-Speed'
    [0] USB port path: '2-3-4'
    [0] kn_number: '0x1A0710BC'
    [0] Connectable: 'True'
    [0] Firmware: 'KDP2 Loader/L'
    $ ./kl630_demo_generic_data_inference.exe
    upload model ... OK
    read image ... OK
    inference failed, error = 102 (Device is not able to allocate DDR memory)
    $ ./kl630_demo_generic_image_inference_post_yolo.exe
    upload model ... OK
    read image ... OK
    windows command prompt
    # [debug - control transfer]
    bRequestType = 0x40
    bRequest   = 0x80
    wValue    = 0x0(0)
    wIndex    = 0x0
    wLength   = 0
    control bRequest = 0x80 (do fifoq reset)
    Unable to get usb fifo for endpoint
    bRequestType = 0x1c
    bRequest   = 0xd
    wValue    = 0xb634(46644)
    wIndex    = 0x0
    wLength   = 0
    Not a PLUS control cmd
    bRequestType = 0x1c
    bRequest   = 0xd
    wIndex    = 0x0
    wLength   = 0
    bRequestType = 0x40
    bRequest   = 0xff
    wValue    = 0x0(0)
    wIndex    = 0x0
    wLength   = 0
    control bRequest = 0xff (do reboot)
    receive SIGNAL: 15
    sig_kill end
    receive SIGNAL: 2
    sig_kill end
    VMF_NNM_Usbd_Close pthread_join ok
    main end
    [run] waitpid loader_status: 0 ret: 121
    [run] exited, status: 0
    [if_exit_call_back_kp_fw] kp_firmware exit status 0
    [if_exit_call_back_kp_fw] boot_mode: USB-Boot
    [if_exit_call_back_kp_fw] boot_kp_firmware_partition_idx: 0
    [if_exit_call_back_kp_fw] boot_from_flash_failure_count: 0
    Kneron Daemon (Active)
    Ver. 1.0.0.1212
    Build Time: Dec 12 2023 13:39:01
    [main] boot_kp_loader_partition_idx: 0
    [main] boot_kp_loader_failure_count: 0
    [run] child_pid: 655
    Kneron Loader
    Ver. 1.0.0.1212
    Build Time: Dec 12 2023 13:39:02
    [main] boot_mode: USB-Boot
    [main] boot_kp_firmware_partition_idx: 0
    [main] boot_from_flash_failure_count: 0
    [kdp2_usb_loader_init] KDP2 FW is running in loader mode
    bRequestType = 0x0
    bRequest   = 0x0
    wValue    = 0x0(0)
    wIndex    = 0x0
    wLength   = 0
    bRequestType = 0x0
    bRequest   = 0x0
    wValue    = 0x0(0)
    wIndex    = 0x0
    wLength   = 0
    USB device is ready
    USB is connected
    [usb_boot_process] start receiving fw through usb ...
    [usb_boot_process][untar_cmd] tar -xf /tmp/kp_firmware.tar --directory /tmp/plus && sync
    [usb_boot_process][rm_cmd] rm /tmp/kp_firmware.tar
    [usb_boot_process] received fw is done !
    [if_exit_call_back_loader] kp_loader exit status 0
    [if_exit_call_back_loader] boot_kp_loader_partition_idx: 0
    [if_exit_call_back_loader] boot_kp_loader_failure_count: 0
    [run] child_pid: 671
    [MemMgr][Info]: Start to use memory manager library version 4.2.0.0 !!
    [MemMgr][Info]: Open EDMC device driver version 6.3.0.2 successful !!
    Kneron Firmware
    Ver. 1.3.0.314
    Build Time: Mar 14 2025 16:26:39
    [main] app_initialize
    >> Start running KL630 KDP2 companion mode ...
    starting KDP2 middleware ...
    KDP2 FW is running in usb-boot mode
    write descriptors1
    bRequestType = 0x0
    bRequest   = 0x0
    wValue    = 0x0(0)
    wIndex    = 0x0
    wLength   = 0
    bRequestType = 0x0
    bRequest   = 0x0
    wValue    = 0x0(0)
    wIndex    = 0x0
    wLength   = 0
    USB device is ready
    USB is connected
    bRequestType = 0x40
    bRequest   = 0x80
    wValue    = 0x0(0)
    wIndex    = 0x0
    wLength   = 0
    bRequestType = 0x1c
    bRequest   = 0xcd
    wValue    = 0xb637(46647)
    wIndex    = 0x0
    wLength   = 0
    bRequestType = 0x1c
    bRequest   = 0xcd
    wIndex    = 0x0
    wLength   = 0
    mdl_parser_open(): fw parser hdl=0x0x2c948
    =================== Parser NEF info ===================
    Model Amount : 1
    [0] Models ID : 211
    [0] Models Version: 0x22FA
    [0] Command.bin Length : 516088
    [0] Command.bin Buffer Virtual Address : 0x50001cc0
    [0] Weight.bin Length : 9017440
    [0] Weight.bin Buffer Virtual Address : 0x5007fcc0
    [0] Setup.bin Length : 776
    [0] Setup.bin Buffer Virtual Address : 0x50919520
    [0] Working Buffer Length : 4915200
    [0] Working Buffer Virtual Address : 0x5091aa00
    [0] Output Buffer Length : 2284800
    [0] Input Buffer Length : 1638400
    [0] [dim] Input 0 Row: 640
    [0] [dim] Input 0 Col: 640
    [0] [dim] Input 0 Channel: 3
    [0] [postproc] Output num: 3
    VMTK_IE_Init(): IE Version. 0x0001
    VMTK_NPU_Init(): NPU Version. 0x0001
    Set NPU timeout failed
    physical memory size: 268435456 bytes
    edmc start address: 0x3e00000
    edmc end address: 0x2fe8
    edmc available size: 268423192 bytes
    bRequestType = 0x40
    bRequest   = 0x84
    wValue    = 0x0(0)
    wIndex    = 0x0
    wLength   = 0
    control bRequest = 0x84 (do DDR help boundary adjust - NOT support)
    bRequestType = 0x1c
    bRequest   = 0xcd
    wIndex    = 0x0
    wLength   = 0
    bRequestType = 0x1c
    bRequest   = 0xcd
    wIndex    = 0x0
    wLength   = 0
    bRequestType = 0x40
    bRequest   = 0x82
    wValue    = 0x32a2(12962)
    wIndex    = 0x6fa
    wLength   = 0
    control bRequest = 0x82 (do fifoq configure)
    allocating memory for fifoq: image 3 x 16599040, result 3 x 2293760, total 56678400 bytes
    bRequestType = 0x1c
    bRequest   = 0xcd
    wIndex    = 0x0
    wLength   = 0
    bRequestType = 0x1c
    bRequest   = 0xcd
    wIndex    = 0x0
    wLength   = 0
    [Error] Allocate memory space for inproc input failed
    [VMF_NNM_Inference_App_Execute] Request ncpu_package failed
    感謝~~
  • Hi RayYu,
    error log是記憶體不足,請幫忙在KL630 user space 下指令"fw_printenv"並貼給我檢查一下,也幫忙確認KL630開機後是否有跑其他程式,可以下指令"ps"查看,記憶體不足推測是跑了多個程式造成。
  • 您好,請參考以下資訊,謝謝~~
    LOG of "fw_printenv" command
    # fw_printenv
    baudrate=115200
    bootcmd=run setargs;nand read 0xa00000 0x1e0000 0x400000;nand read 0x1400000 0x180000 0x60000;bootz 0xa00000 - 0x1400000
    bootdelay=3
    ethact=dweqos
    ethaddr=02:00:DC:01:10:AE
    fdt_high=0xffffffff
    gatewayip=172.23.0.1
    ipaddr=192.168.3.10
    modelname=Schubert
    netmask=255.255.0.0
    phy_mode=rmii
    root=/dev/mtdblock4
    serverip=172.17.0.12
    setargs=setenv bootargs;setenv bootargs root=${root} mem=16M@0x00000000 mem=45M@0x1100000 console=0,${baudrate} phy_mode=${phy_mode} ${mtdparts}
    stderr=serial
    stdin=serial
    stdout=serial
    Log of "PS" command
    # ps
    PID  USER   COMMAND
      1 root   init
      2 root   [kthreadd]
      3 root   [ksoftirqd/0]
      5 root   [kworker/0:0H]
      6 root   [kworker/u2:0]
      7 root   [lru-add-drain]
      8 root   [kdevtmpfs]
      9 root   [oom_reaper]
      10 root   [writeback]
      11 root   [kcompactd0]
      12 root   [crypto]
      13 root   [bioset]
      14 root   [kblockd]
      15 root   [cfg80211]
      16 root   [kworker/0:1]
      17 root   [watchdogd]
      18 root   [rpciod]
      19 root   [xprtiod]
      20 root   [kswapd0]
      21 root   [nfsiod]
      47 root   [bioset]
      48 root   [spi0]
      49 root   [kworker/u2:1]
      51 root   [bioset]
      52 root   [bioset]
      53 root   [bioset]
      54 root   [bioset]
      55 root   [bioset]
      56 root   [bioset]
      57 root   [spi1]
      59 root   [ipv6_addrconf]
      60 root   [kworker/0:2]
      61 root   [kworker/0:1H]
      75 root   /sbin/syslogd -n
      76 root   /sbin/klogd -n
     105 root   /usr/sbin/xinetd -pidfile /var/run/xinetd.pid
     111 root   [ubi_bgt0d]
     115 root   [ubifs_bgt0_0]
     197 root   ./rtsps -c stream_server_config.ini
     198 root   ./kp_firmware_host_stream
     199 root   -/bin/sh
     215 root   [sensor_queue]
     216 root   [sensor_queue]
     230 root   telnetd
     231 root   -sh
     234 root   /sbin/watchdog -T 3 -t 2 /dev/watchdog
     247 root   /mnt/flash//plus/kp_daemon/bin/kp_daemon
     332 root   [kp_firmware]
     377 root   ps
  • Hi RayYu,
    在KL630上使用"ps"指令可以看到系統已經啟動了"rtsps"和"hos_stream"(分別為 PID 197 和 198),這些是 IPCAM 的範例程式。這些程序會在開機時自動啟動,是因為系統執行了/mnt/flash/etc/rc.local 這支script。您可以參考 rc.local 的內容,進一步了解 KL630 開機時的執行流程。
    針對您目前的需求,如果不需要這些範例程式自動執行,只需要將 rc.local 中的 ./start.sh 這一行註解掉即可。
  • 謝謝Nick 協助,中止 rtsps 與 hos_stream程序,或修改rc.local 後可以執行推論了
