Issue with camera module "ZF-BP3-SH"
Hello, I'm a person working on a project with "ZF-BP3-SH-V2.2.10.20".
I'm contacting you because I have an inquiry about "enroll".
Currently, I've asked for registration front, right, left, up, and down, and the code runs well if the face is well recognized.
But that's where the problem comes from.
If you ask the ZF-BP3-SH model to roll and recognize the arm rather than the face, the sensor dies in the middle while sending NOTE a message saying it's not the face. As per the document, unplugging and inserting the connector works fine again, but this is too inefficient.
The sensor does not die in the program provided by us.
I didn't see any other information in the document except that if you ask for enroll, you will return the reason for failure to note, and you will return the success or timeout to reply.
Is there anything else about this?
I'm still in a learning position, so I'm lacking a lot.
Please answer me.
Thank you for reading it.
  • I've solved this problem.
    Raspberry Pi has powered it up, but the method is unstable.
    The problem has been solved by supplying external power separately.
  • It’s great to hear that the issue has been resolved.
    Feel free to contact us again if you encounter any other problems.
