Missing IMX678 support files (driver, DTS, config/ini) for KL730 platform
I’m working on integrating the Sony IMX678 with the Kneron KL730 platform, and I would like to confirm the correct workflow and obtain the missing support files.
From the documentation:
- KL730 HDK Board User Manual (v1.04, July 18, 2025) — describes RTSP streaming via
stream.ini
, referencing./Resource/VIC/0/imx678_3840x2160_ch0.cfg
. - Leipzig SDK Multimedia Framework Programming Guide (v1.05, June 9, 2025) — explains that sensor config and PQ files are loaded during
VMF_VSRC_Init()
. - Leipzig SDK 3A Integration Guide (v1.03, Sept 12, 2024) — outlines how AE/AWB/AF integrate with specific sensors.
Based on these, IMX678 should be supported — but after searching thoroughly, I could not find the necessary files. Specifically:
- No IMX678 kernel driver (
imx678.c
) is present in the SDK or BSP source underdrivers/media/i2c
. - No device tree entries / DTB examples exist for IMX678.
- No sensor config/ini files (e.g.,
) are present in the SDK resource folders or BSPs.
I have already searched in:
- The Leipzig SDK and its
Resource/
directories, - The KL730 HDK package,
- The BSPs you provided: BSP_imx678_host_stream and BSP_imx678_hico_mipi.
Unfortunately, none of these contain the IMX678 driver, DTS, or config/ini files that the manuals reference.
Could you please confirm and provide:
- The Linux kernel driver source for IMX678 (and build instructions).
- The Device Tree / DTB example for IMX678 on KL730 (MIPI lanes, I²C addr, GPIOs, link-frequencies).
- The config/ini files (e.g.,
, PQ tuning files, autoscene configs) that are mentioned in the manuals. - Confirmation of the correct integration workflow (e.g., is
stream.ini
+streamer
the recommended way to bring up IMX678, or is there another demo path?).
At this point I have the documentation, SDK, HDK, and BSP packages, but without the driver, DTS, and config files, I cannot modify configure for IMX678. Could you clarify where these files are distributed, or if they need to be requested separately?
