Kneron Model Zoo Classification Model 與 ImageNet DataSet Accuracy 問題
(Q1) 下載 Kneron Model Zoo上 Classification onnx 轉成 nef 後, 測試 ImageNet inference 5萬張jpg圖片
可成功跑完測試流程, 但 Accuracy 不如預期?
請幫忙看一下轉換流程, 哪裡參數設定有問題 ? (因為用這組參數轉 Keras MobileNetV2.h5 可得正常Accuracy)
def preprocess(pil_img):
image = tf.io.read_file(pil_img)
image = tf.io.decode_jpeg(image, channels=3)
image = tf.image.resize(image, [224, 224])
image = tf.cast(image / 255., tf.float32)
array = tf.Session().run(image)
return array
m = onnx.load("/data1/benchmark_model/MobileNetV2.onnx")
m = ktc.onnx_optimizer.onnx2onnx_flow(m, eliminate_tail=True, opt_matmul=False)
onnx.save(m,'MobileNetV2_kneron_opt.onnx')
或者可以提供Model Zoo這兩個 MobleNetV2 & Resnet50 onnx 的正確轉換 python sample code ?
(Q2) Resnet50 從網站download resnet50 pb轉成 32-bit tflite 再轉 onnx 會出現問題 (有去掉ArgMax)
bottom_nodes = []
bottom_nodes.append("ArgMax")
m = ktc.onnx_optimizer.tflite2onnx_flow("/data1/benchmark_model/resnet50_v1.tflite", False, bottom_nodes)
onnx.save(m,'resnet50_v1_opt.tflite.onnx')
(base) root@fa228aeb0eb5:/data1/benchmark_model# python3 resnet50_v1_tflite_to_nef.py
Using TensorFlow backend.
found unsupported op type ARG_MAX, if the node is at buttom, we recommend you use "-bottom_nodes" to delete this node
New Qunatized information saved
File "resnet50_v1_tflite_to_nef.py", line 78, in <module>
m = ktc.onnx_optimizer.tflite2onnx_flow("/data1/benchmark_model/resnet50_v1.tflite", True, bottom_nodes)
File "/workspace/miniconda/lib/python3.7/site-packages/ktc/onnx_optimizer.py", line 308, in tflite2onnx_flow
return tflite2onnx.main(tflite_path, '/tmp/tflite_converted.onnx', not release_mode, bottom_nodes)
File "/workspace/libs/ONNX_Convertor/tflite-onnx/onnx_tflite/tflite2onnx.py", line 379, in main
out_value_info = set_end_node(b_node.node_list[-1], b_node.node_output_shape.tolist())
IndexError: list index out of range
可否協助提供這個ResNet50 tflite 32-bit 正確的轉換方式?
thanks,
Giga
@GigaHsu
Hi Giga,
關於影響推論的結果 (Accuracy) 的可能性很多,您可以先檢查下面幾點:
關於 MobleNetV2 & Resnet50 onnx 正確轉換成 nef 的 python sample code,您可以參考這個連結:
關於第二個問題,看到您的錯誤訊息,事實上您的 tflite 沒有成功去掉 ArgMax 這個 op type,所以才會無法導致轉成 keron onnx,你再去除 ArgMax 這個 type 的時候可以考慮試試使用 -bottom_nodes resnet_model/dense/BiasAdd,應該就可以成功轉出 onnx 了。
Hi Andy,
你建議設定 bottom_nodes.append("resnet_model/dense/BiasAdd")
可以成功轉出 .nef 檔案 可跑, 只是Accuracy 非常差 只有 0.1 %.
Q1. 想再問一下 Accuracy 的問題.
你說的, 大概Pow都有跟我說過,都能理解.
只是 MobileNetV1/MobileNetV2/Resnet50 都是使用相同ImageNet dataset 5萬張
有些模型 Accuracy 就不好,有些就能接受(> 68%) 我也理解轉換 8-bit tflite 需要輸入照片越多越好,
找到max/min值,以便得到更好的8-bit model的zero-point與scale參數, 所以我excel有列10張跟100張的Accuracy區別.
想問一下MobileNetV1/MobileNetV2/Resnet50 這3個Models 正確的def preprocess(pil_img): 是否相同或不同?
同樣設定,卻跑出不同的Accuracy. 如果是你們來轉, def preprocess(pil_img) 使用ImageNet dataset 又是如何撰寫 才是正確的作法?
thanks,
Giga
@GigaHsu
Hi GigaHsu,
您成功轉出的 .nef 檔案是去除 ArgMax 這個 type 的 model,不知道您推論之前是否有再做後處理 ( ArgMax ) 回去,做完之後 Accuracy 應該不會只有 0.1 %,因為不知道您的 Accuracy 是怎麼計算的,如果您方便的話是否可以提供計算 Accuracy 的 Code 與相關檔案。
基本上每個 Model 會有相對應的 preprocess ,這個 preprocess 是因為要將 data 轉換成模型需要的格式,送進模型推論所需要的 preprocess,所以與模型的架構沒有直接的關聯性,比較有關聯的會是在訓練模型時的一些設定。
會有同樣的設定,跑出不同的 Accuracy 也有可能是因為訓練模型時參數的設定、訓練模型的 datasets 導致,preprocess 如何撰寫會依個人需求而有所改變,所以沒有一定的標準答案,但如果您是使用耐能的架構,那範例中的 preprocess 就可以參考。
Hi Andy,
我簡化問題到10張圖計算Accuracy. 方便你分析問題.
.tgz file 放入兩個tflite model (mobilenetv1, resnet50v1)
進入Kneron docker 後, copy tgz 至 /data1 folder 解開.
(1) mobilenetv1_tflite_to_nef.py
執行結果 : mobilenetv1_tflite_to_nef_ok.txt Accuracy = 60 %
(2) resnet50_v1_tflite_to_nef.py
執行結果 : resnet50_v1_tflite_to_nef_failed.txt 執行結果 Accuracy = 0 %
有空的話, 協助我看一下 Resnet50v1 在 KL720 上 accuracy issue : resnet50v1轉nef的code需要如何修正.
thanks,
Giga
@GigaHsu
Hi GigaHsu,
您的 Resnet50v1.tflite model 是量化過的 model ,這邊建議使用未量化過的 float model。
Hi Andy,
轉pb的時候有去掉 converter.target_spec.supported_ops = [tf.lite.OpsSet.TFLITE_BUILTINS_INT8]
改用 converter.optimizations = [tf.lite.Optimize.DEFAULT].
(1) resnet50_v1.tflite.png (有用Netron檢查Conv2D是float32)
(2) resnet50_v1.quant.tflite.png (使用converter.target_spec.supported_ops = [tf.lite.OpsSet.TFLITE_BUILTINS_INT8]的結果 Conv2D是int8)
Q1 : .tgz 附的是 (1) resnet50_v1.tflite, Accuracy不好 是否跟去掉上面Pad 有關? call tflite2onnx_flow() 第二個參數設True.
m = ktc.onnx_optimizer.tflite2onnx_flow("/data1/resnet50_v1/resnet50_v1.tflite", True, bottom_nodes)
否則會轉不出來.nef. 會說input格式有問題.
Q2 : 你說resnet50_v1.tflite是量化過的 model, 可否用Netron指出位置. 我看一下.
請問如果是量化過的Model 也能成功轉出.nef 嗎? 因為resnet50_v1.tflite 可以轉出.nef 可跑,只是Accuracy不好.
thanks,
Giga
@GigaHsu
Hi GigaHsu,
Q1.
這裡有幫您測試過,轉出來的模型有沒有 Pad 都是有相同的行為。
所以我認為 Accuracy 不好應該是跟有沒有 Pad 沒有關係的。
至於 call tflite2onnx_flow() 第二個參數設定 True 的原因是將 model input shape 轉成 channel last,Kneron Tool Chain 所需要的 input shape。
Q2.
Netron 指出的位置如圖,點開 filter 的時候可以看得出這個 model 有沒有被量化過。
目前對於量化過的模型的轉換功能還在初期,所以會建議 tflite model 必須是未量化過的。
這篇給您參考:https://www.kneron.com/forum/discussion/comment/594#Comment_594
Hi Andy,
轉tflite 去掉 converter.optimizations = [tf.lite.Optimize.DEFAULT]
只保留 tflite_quant_model = converter.convert()
可得 filter 為 float 格式 :
但執行 resnet50_v1_tflite_to_nef.py
結果 Accuracy = 0 % 有空再幫忙看原因為何?
gigahsu@gigahsu-Z390F:~/resnet50_v1/tmp$ ls
resnet50_v1.tar.00.gz resnet50_v1.tar.01.gz
gigahsu@gigahsu-Z390F:~/resnet50_v1/tmp$ cat resnet50_v1.tar.* | tar -zxv
resnet50_v1.tflite
resnet50_v1.tar.00.gz resnet50_v1.tar.01.gz resnet50_v1.tflite
thanks,
Giga
@GigaHsu
Hi GigaHsu,
看過您的 model 也對您的 model 做過 10 張的量化是可以順利的轉成 nef 的。
我認為有 Accuracy = 0 % 這個情況可能是 .tflite 模型本身的問題,建議您確認一下你的模型。
