[common][error][hw_utils.cc:109][GetFmtParam] Unsupported data format RAW8
Cmd exec error: exit status 1,
Using TensorFlow backend.
Cannot inference all shapes. If no other error is raised, please ignore this message.
terminate called after throwing an instance of 'std::out_of_range'
output=stdout, stderr=stderr)
subprocess.CalledProcessError: Command '['./compilerIpevaluator_520.sh', '/docker_mount/convert_script/yolov5_model/yolov5s-opt.onnx']' returned non-zero exit status 1.
看起來錯誤是因為沒有填入model id所造成的,除了模型onnx檔案之外,model id, version與量化用的圖片也都要輸入喔
UI 可以在改善看看 start 的時候沒跳出必填,
另外一個就是我直接使用 yolov5 export 出來的模型 會報這樣的錯誤
https://i.imgur.com/ONLb06e.png
running compiler and IP evaluator...
Compiler config generated.
what(): map::at
./compilerIpevaluator_520.sh: line 32: 55 Aborted (core dumped) $LIBS_FOLDER/compiler/compile 520 $model $TMP_FOLDER/config_compiler.json warning compile.log
File "scripts/onnxFlow.py", line 67, in <module>
eval_result = km.evaluate()
File "/workspace/miniconda/lib/python3.7/site-packages/ktc/toolchain.py", line 128, in evaluate
subprocess.run(['./compilerIpevaluator_520.sh', input_model_path], check=True)
subprocess.CalledProcessError: Command '['./compilerIpevaluator_520.sh', '/data1/input.onnx']' returned non-zero exit status 1.
使用 code 去跑會出現這個問題
what(): map::at
./compilerIpevaluator_520.sh: line 32: 84 Aborted (core dumped) $LIBS_FOLDER/compiler/compile 520 $model $TMP_FOLDER/config_compiler.json warning compile.log
File "test_script.py", line 24, in <module>
(base) root@65a275970522:/docker_mount/convert_script#
@johnson luo
Hi johnson luo,
您是否可以提供您 export 出來的 yolov5s.onnx 與 yolov5s-opt.onnx,方便找出現錯誤訊息原因。
@Andy Hsieh
已回覆在另一篇,謝謝!
