How to save the streamd camera image in KL630 in ther board ?
As shown in the attached video, the inferred value keeps showing strange values, so I would like to check whether the input is entered correctly.
3DCNN receives 128x128x3 image input and inputs it into an array of 15 dim.
The output of the deep learning model produces classification results of 0, 1, 2, and 3.
Is there a way to save to video and check video input on the KL630?
What I am suspicious of is that 15 input images are input.
I would like to ask you to check whether the input of the AI model is proper.
I also attached the log. plz help me.
It might be hard to figure out the issue just from the capture log. Could you provide more files, such as the KL630 code, the nef model, and the original model before converting it to nef, so that we could check the model input? Thank you for your help.
I uploaded nef file and source codes in following link
https://www.kneron.com/forum/discussion/495/kl630-inference-error#latest
Thank you for providing the files.
Your .nef model input does look okay, with a shape of (1, 3, 128, 128)
As you suspected, the num_image is set to 15, meaning that there are 15 images as your input. You might want to set them to 1.
When you say "save to video," do you mean to export what the camera is showing into a video file? It should be doable.
If you mean to inference videos on KL630, yes, it's doable, but you will need to inference the images one by one.
Before directly using your model on host_stream, you might want to test to see if your model can actually run on companion mode.
When doing model porting, please follow the steps:
Thank you Maria.
The model I am trying to infer on KL630 is aimed at inferring video input consisting of (1,3,128,128) x 15 images.
This model is similar to this one.
https://www.tensorflow.org/tutorials/video/video_classification
You commented as,
=> I don’t think this part fits what I’m trying to do.
If I chagned to
Just inf_config.num_image = 1;
I think this will result in a (1,3,128,128) x 1 image classification model.
I'm asking because I think the inferred value will be a strange value if I change it to .
I am curious whether what you mean by saying that it is possible to infer videos from the KL630 matches what I intended.
And please help me, where I can changed
Maybe host_stream.ini ?? Fps part?
[nnm]
ModelPath = "nef/models_630_3dcnn_LR_4_id35000.nef"
ModelId = 35000 # for yolo only - switch model(If there are multiple yolo models in one nef file)
JobId = 3002 # for job mapping in application_init.c
InferenceStream = 1 # Inference stream index
Threshold = 0.5 # for yolo only(JobId = 11)
Fps = 1 # Image input fps for NPU inference
GetImageBufMode = 0 # 0: block mode 1: non-block mode
RoiEnable = 0 # Enable ROI for nnm detect
RoiX = 0 # ROI start x
RoiY = 0 # ROI start y
DrawBoxEnable = 1 # draw object bounding box on stream0
OnlyPerson = 0 # only draw person bounding box when DrawBoxEnable
#(so far for yolo only, JobId = 11)
DrawOnResize = 0; # If InferenceStream is 0. This setting needs to be enabled. The box will be drawn on all resize streams.
I changed it my_kl630_sin_example_inf.c
// Image buffer address should be just after the header
//inf_config.num_image = 15; // For 15fps
inf_config.num_image = 1; // For 15fps 241028
inf_config.image_list[0].image_buf = (void *)((uint32_t)_input_header + sizeof(my_kl630_sin_example_header_t));
inf_config.image_list[0].image_width = _input_header->width;
inf_config.image_list[0].image_height = _input_header->height;
inf_config.image_list[0].image_channel = 3;
//inf_config.image_list[0].image_format = KP_IMAGE_FORMAT_RGB565; // Assume RGB565
inf_config.image_list[0].image_format = KP_IMAGE_FORMAT_YUV420; // Assume yuv420
inf_config.image_list[0].image_norm = KP_NORMALIZE_KNERON; // This depends on model
inf_config.image_list[0].image_resize = KP_RESIZE_ENABLE; // Default: enable resize
inf_config.image_list[0].image_padding = KP_PADDING_DISABLE; // Default: disable padding
and got following error in the KL630 with Error 131
Inference Configuration: Image Width: 128, Height: 128
Model ID: 35000, Output Buffer: 0xa56e0
Output Buffer Address: 0xa56e0
Check_ERROR 2
About to execute inference with model ID: 35000
[kmdw_ncpu_pre_proc_thread] error: exist cpu op !!!
NPU Proc: Error occured on Pre Proc
Post Proc: Error occurred on NPU Proc
Check_ERROR 2.2
After inference execution: Result: 131
Inference failed with result code: 131
Inference execution failed or result is invalid.
Final Result: 102, Mapped Class: 0
Class ID: -1498553451
Class Score: -15636851853132277000000000.000000
please help me, Maria
The error code 131 is KP_FW_ERROR_MODEL_EXIST_CPU_NODE_131, which indicates that your model has CPU nodes. KL630 doesn't support CPU nodes, so please edit your onnx model and cut off the CPU nodes, then add back the nodes on your host side.
Could you provide the following files/information? Thanks!
-The original model and the optimized onnx model
-The data files used in quantization (images or videos)
-The Python script for converting the model into an NEF file
-Your Kneron toolchain verion, available by using the command: cat /workspace/version.txt
We recommend you to use the E2E simulator (ktc.kneron_inference) in the Kneron toolchain to verify your onnx model and NEF model's inference results first before deploying the model.
Reference: 3. Floating-Point Model Preparation - Document Center (kneron.com)
Thank you for explaining your model. Could you also specify what exactly you're trying to inference? Are you trying to inference a video of a person to figure out what the person is doing? Or are you trying to inference something else?
Hi YOUNGJUN,
Since the process of porting the model to the KL630 is quite complex, please follow the model porting steps provided by Maria and verify that the inference result at each step is correct. After confirming this should you proceed with porting the model to the KL630. This approach will also simplify the debugging process.
You can find detailed instructions at the link below.
