KL720 SDK-v1.1.0 application example are not getting executed
I have KL720 Evaluation Module. I am running the SDK examples on the same. I have taken the Leipzig SDK examples user guide as a referance. I am able to compile the examples given in SDK/SDK/02_APP/02_Software_Tool_Kit/SDK/sdk/apps/examples/ directory and its respective output binaries in SDK/SDK/02_APP/02_Software_Tool_Kit/SDK/sdk/apps/bin/ path. I have used tftp to transfer file from host PC to EVM in /tmp folder. When I try to execute command to run any binary it is giving the error of file permission/unknown file.
E.G for streamer examples the command is : streamer -c stream.ini [-D] [-h] [-v] [-t]
Response :
./streamer
./streamer: error while loading shared libraries: libmsgbroker.so.0: cannot open shared object file: No such file or directory
I checked the file permissions and made sure that they are executable. Can anyone please help me to understand how we can run the example binary on evm? Am I missing out something?
Your quick help would be very much appreciated. Thank you.
Vidhi V.
@Vidhi
Hi Vidhi,
Since you’ve raised the same question on the forum, I’ll provide a consolidated answer in your new discussion thread.
I have moved the content to the following link:
https://www.kneron.com/forum/discussion/511/kl720-sdk-v1-1-0-application-example-are-not-getting-executed#latest
