KL630 EVK 執行 Generic Image Inference的錯誤訊息
您好,我在KL630_V01 96board上用 windows PC 上面執行 ./kl630_demo_generic_image_inference_post_yolo
請問何種原因出現以下錯誤訊息,謝謝:
$ ./kl630_demo_generic_image_inference_post_yolo
connect device ... OK
upload firmware ... OK
upload model ... OK
read image ... OK
starting inference loop 10 times:
inference failed, error = -7 (USB: Operation timed out)
另外在telnet連線上也會看到以下訊息
[_get_model_info] get model info send fw_info response failed, sts 0
[kdp2_usb_companion_image_thread] error !! inf image size (739468) is bigger than buffer size (20480)
Hi RayYu,
請問您有做了哪些改動呢?
收到Kneron 的96 board(KL630_V01_20230313)之後就按照KL630 96board User Manual以及Getting started的流程來操作(https://doc.kneron.com/docs/#plus_c/getting_started/),簡列操作流程如下供參考:
1.power on reset 96board
2.telnet 192.168.3.10
3. switch to Kneron PLUS(companion)
4.用Kneron DFUT update to "USB boot " and RUN
5.在windows 打開MYSYS2上執行./kl630_demo_generic_image_inference_post_yolo
Hi RayYu,
請問您PLUS是使用哪個版本呢?
也請幫忙提供KL630這端完整的log做查看,感謝!
Hi Nick,
您好,Kneron PLUS用的是kneron_plus_v3.1.1, 在windows上編譯用General example時 cmake 4.0.0(自動安裝)
另外後續更新了96 board firmware SDK 2.5.5後,error code 卻變成102
執行時的LOG如下(MYSYS2+ Telnet (CMD prompt)):
renyu@user MINGW64 /e/Prolific_2025/Kneron_tmp/kneron_plus/build/bin
$ ./scan_devices.exe
scanning kneron devices ...
number of Kneron devices found: 1
listing devices infomation as follows:
[0] scan_index: '0'
[0] port ID: '526'
[0] product_id: '0x630' (KL630)
[0] USB link speed: 'High-Speed'
[0] USB port path: '2-3-4'
[0] kn_number: '0x1A0710BC'
[0] Connectable: 'True'
[0] Firmware: 'KDP2 Loader/L'
$ ./kl630_demo_generic_data_inference.exe
upload model ... OK
read image ... OK
inference failed, error = 102 (Device is not able to allocate DDR memory)
$ ./kl630_demo_generic_image_inference_post_yolo.exe
upload model ... OK
read image ... OK
windows command prompt
# [debug - control transfer]
bRequestType = 0x40
bRequest = 0x80
wValue = 0x0(0)
wIndex = 0x0
wLength = 0
control bRequest = 0x80 (do fifoq reset)
Unable to get usb fifo for endpoint
bRequestType = 0x1c
bRequest = 0xd
wValue = 0xb634(46644)
wIndex = 0x0
wLength = 0
Not a PLUS control cmd
bRequestType = 0x1c
bRequest = 0xd
wIndex = 0x0
wLength = 0
bRequestType = 0x40
bRequest = 0xff
wValue = 0x0(0)
wIndex = 0x0
wLength = 0
control bRequest = 0xff (do reboot)
receive SIGNAL: 15
sig_kill end
receive SIGNAL: 2
sig_kill end
VMF_NNM_Usbd_Close pthread_join ok
main end
[run] waitpid loader_status: 0 ret: 121
[run] exited, status: 0
[if_exit_call_back_kp_fw] kp_firmware exit status 0
[if_exit_call_back_kp_fw] boot_mode: USB-Boot
[if_exit_call_back_kp_fw] boot_kp_firmware_partition_idx: 0
[if_exit_call_back_kp_fw] boot_from_flash_failure_count: 0
Kneron Daemon (Active)
Ver. 1.0.0.1212
Build Time: Dec 12 2023 13:39:01
[main] boot_kp_loader_partition_idx: 0
[main] boot_kp_loader_failure_count: 0
[run] child_pid: 655
Kneron Loader
Ver. 1.0.0.1212
Build Time: Dec 12 2023 13:39:02
[main] boot_mode: USB-Boot
[main] boot_kp_firmware_partition_idx: 0
[main] boot_from_flash_failure_count: 0
[kdp2_usb_loader_init] KDP2 FW is running in loader mode
bRequestType = 0x0
bRequest = 0x0
wValue = 0x0(0)
wIndex = 0x0
wLength = 0
bRequestType = 0x0
bRequest = 0x0
wValue = 0x0(0)
wIndex = 0x0
wLength = 0
USB device is ready
USB is connected
[usb_boot_process] start receiving fw through usb ...
[usb_boot_process][untar_cmd] tar -xf /tmp/kp_firmware.tar --directory /tmp/plus && sync
[usb_boot_process][rm_cmd] rm /tmp/kp_firmware.tar
[usb_boot_process] received fw is done !
[if_exit_call_back_loader] kp_loader exit status 0
[if_exit_call_back_loader] boot_kp_loader_partition_idx: 0
[if_exit_call_back_loader] boot_kp_loader_failure_count: 0
[run] child_pid: 671
[MemMgr][Info]: Start to use memory manager library version 4.2.0.0 !!
[MemMgr][Info]: Open EDMC device driver version 6.3.0.2 successful !!
Kneron Firmware
Ver. 1.3.0.314
Build Time: Mar 14 2025 16:26:39
[main] app_initialize
>> Start running KL630 KDP2 companion mode ...
starting KDP2 middleware ...
KDP2 FW is running in usb-boot mode
write descriptors1
bRequestType = 0x0
bRequest = 0x0
wValue = 0x0(0)
wIndex = 0x0
wLength = 0
bRequestType = 0x0
bRequest = 0x0
wValue = 0x0(0)
wIndex = 0x0
wLength = 0
USB device is ready
USB is connected
bRequestType = 0x40
bRequest = 0x80
wValue = 0x0(0)
wIndex = 0x0
wLength = 0
bRequestType = 0x1c
bRequest = 0xcd
wValue = 0xb637(46647)
wIndex = 0x0
wLength = 0
bRequestType = 0x1c
bRequest = 0xcd
wIndex = 0x0
wLength = 0
mdl_parser_open(): fw parser hdl=0x0x2c948
=================== Parser NEF info ===================
Model Amount : 1
[0] Models ID : 211
[0] Models Version: 0x22FA
[0] Command.bin Length : 516088
[0] Command.bin Buffer Virtual Address : 0x50001cc0
[0] Weight.bin Length : 9017440
[0] Weight.bin Buffer Virtual Address : 0x5007fcc0
[0] Setup.bin Length : 776
[0] Setup.bin Buffer Virtual Address : 0x50919520
[0] Working Buffer Length : 4915200
[0] Working Buffer Virtual Address : 0x5091aa00
[0] Output Buffer Length : 2284800
[0] Input Buffer Length : 1638400
[0] [dim] Input 0 Row: 640
[0] [dim] Input 0 Col: 640
[0] [dim] Input 0 Channel: 3
[0] [postproc] Output num: 3
VMTK_IE_Init(): IE Version. 0x0001
VMTK_NPU_Init(): NPU Version. 0x0001
Set NPU timeout failed
physical memory size: 268435456 bytes
edmc start address: 0x3e00000
edmc end address: 0x2fe8
edmc available size: 268423192 bytes
bRequestType = 0x40
bRequest = 0x84
wValue = 0x0(0)
wIndex = 0x0
wLength = 0
control bRequest = 0x84 (do DDR help boundary adjust - NOT support)
bRequestType = 0x1c
bRequest = 0xcd
wIndex = 0x0
wLength = 0
bRequestType = 0x1c
bRequest = 0xcd
wIndex = 0x0
wLength = 0
bRequestType = 0x40
bRequest = 0x82
wValue = 0x32a2(12962)
wIndex = 0x6fa
wLength = 0
control bRequest = 0x82 (do fifoq configure)
allocating memory for fifoq: image 3 x 16599040, result 3 x 2293760, total 56678400 bytes
bRequestType = 0x1c
bRequest = 0xcd
wIndex = 0x0
wLength = 0
bRequestType = 0x1c
bRequest = 0xcd
wIndex = 0x0
wLength = 0
[Error] Allocate memory space for inproc input failed
[VMF_NNM_Inference_App_Execute] Request ncpu_package failed
感謝~~
Hi RayYu,
error log是記憶體不足,請幫忙在KL630 user space 下指令"fw_printenv"並貼給我檢查一下,也幫忙確認KL630開機後是否有跑其他程式,可以下指令"ps"查看,記憶體不足推測是跑了多個程式造成。
您好,請參考以下資訊,謝謝~~
LOG of "fw_printenv" command
# fw_printenv
baudrate=115200
bootcmd=run setargs;nand read 0xa00000 0x1e0000 0x400000;nand read 0x1400000 0x180000 0x60000;bootz 0xa00000 - 0x1400000
bootdelay=3
ethact=dweqos
ethaddr=02:00:DC:01:10:AE
fdt_high=0xffffffff
gatewayip=172.23.0.1
ipaddr=192.168.3.10
modelname=Schubert
netmask=255.255.0.0
phy_mode=rmii
root=/dev/mtdblock4
serverip=172.17.0.12
setargs=setenv bootargs;setenv bootargs root=${root} mem=16M@0x00000000 mem=45M@0x1100000 console=0,${baudrate} phy_mode=${phy_mode} ${mtdparts}
stderr=serial
stdin=serial
stdout=serial
Log of "PS" command
# ps
PID USER COMMAND
1 root init
2 root [kthreadd]
3 root [ksoftirqd/0]
5 root [kworker/0:0H]
6 root [kworker/u2:0]
7 root [lru-add-drain]
8 root [kdevtmpfs]
9 root [oom_reaper]
10 root [writeback]
11 root [kcompactd0]
12 root [crypto]
13 root [bioset]
14 root [kblockd]
15 root [cfg80211]
16 root [kworker/0:1]
17 root [watchdogd]
18 root [rpciod]
19 root [xprtiod]
20 root [kswapd0]
21 root [nfsiod]
47 root [bioset]
48 root [spi0]
49 root [kworker/u2:1]
51 root [bioset]
52 root [bioset]
53 root [bioset]
54 root [bioset]
55 root [bioset]
56 root [bioset]
57 root [spi1]
59 root [ipv6_addrconf]
60 root [kworker/0:2]
61 root [kworker/0:1H]
75 root /sbin/syslogd -n
76 root /sbin/klogd -n
105 root /usr/sbin/xinetd -pidfile /var/run/xinetd.pid
111 root [ubi_bgt0d]
115 root [ubifs_bgt0_0]
197 root ./rtsps -c stream_server_config.ini
198 root ./kp_firmware_host_stream
199 root -/bin/sh
215 root [sensor_queue]
216 root [sensor_queue]
230 root telnetd
231 root -sh
234 root /sbin/watchdog -T 3 -t 2 /dev/watchdog
247 root /mnt/flash//plus/kp_daemon/bin/kp_daemon
332 root [kp_firmware]
377 root ps
Hi RayYu,
在KL630上使用"ps"指令可以看到系統已經啟動了"rtsps"和"hos_stream"(分別為 PID 197 和 198),這些是 IPCAM 的範例程式。這些程序會在開機時自動啟動,是因為系統執行了/mnt/flash/etc/rc.local 這支script。您可以參考 rc.local 的內容,進一步了解 KL630 開機時的執行流程。
針對您目前的需求,如果不需要這些範例程式自動執行,只需要將 rc.local 中的 ./start.sh 這一行註解掉即可。
謝謝Nick 協助,中止 rtsps 與 hos_stream程序,或修改rc.local 後可以執行推論了
