python3 main.py -t KL520-cam_isi_async_yolo return -1
Hi
i have complete below steps:
owen@owen-Aspire-3830TG:~/host_lib_v1.0.0/python$ python3 main.py -t KL520-update_app_nef_model
adding devices....
start kdp host lib....
Task: KL520-update_app_nef_model
Start updating fw...
Update SCPU firmware succeeded...
Update NCPU firmware succeeded...
Start updating model...
Update model succeeded...
Start reporting sys status...
Report sys status succeeded...
FW firmware_id 1.5.0.0, build_id 113
de init kdp host lib....
and want to do "KL520-cam_isi_async_yolo" based on README but got problem:
1. From the chart, we know we need to use model `tiny_yolo_v3`.
2. Copy all files (`*.bin`) under `input_models/KL520/tiny_yolo_v3` into `app_binaries/KL520/ota/ready_to_load`.
Q: there are no bin? only models_520.nef, where is the bin file?
what i did is below:
$ cp ../app_binaries/KL520/ssd_fd_lm/fw_* ../app_binaries/KL520/ota/ready_to_load/
$ cp ../input_models/KL520/tiny_yolo_v3/models_520.nef ../app_binaries/KL520/ota/ready_to_load/
3. Enter `python` directory.
4. Run `python main.py -t KL520-update_app_nef_model` (This step may take some time).
5. Run `python main.py -t KL520-cam_isi_async_yolo`.
also got error in "5":
owen@owen-Aspire-3830TG:~/host_lib_v1.0.0/python$ python3 main.py -t KL520-cam_isi_async_yolo
adding devices....
Task: KL520-cam_isi_async_yolo
Starting ISI mode...
Could not set to ISI mode: -1...
could you help provide some comment? thanks.
In ISI mode, KL520 will load firmware and model from flash. So you must update fw and model before ISI inference.
For example yolo, you can find firmware files in /app_binaries/KL520/tiny_yolo_v3/ and model in /input_models/KL520/tiny_yolo_v3/models_520.nef
I think the error you encountered is caused by wrong firmware (ssd_fd_lm), please update all of the files for yolo and try again.
thanks! it is ok now!
