yolox model conversion problem
I was trying to convert this yolox model in kneron toolchain and encountered this error:
Using TensorFlow backend. Traceback (most recent call last): File "convert_yolox.py", line 12, in <module> result_m = ktc.onnx_optimizer.torch_exported_onnx_flow(exported_m) File "/workspace/libs/ONNX_Convertor/optimizer_scripts/pytorch_exported_onnx_preprocess.py", line 30, in torch_exported_onnx_flow m = combo.common_optimization(m) File "/workspace/libs/ONNX_Convertor/optimizer_scripts/tools/combo.py", line 135, in common_optimization fusing.fuse_slice_nodes_into_conv(g) File "/workspace/libs/ONNX_Convertor/optimizer_scripts/tools/fusing.py", line 1084, in fuse_slice_nodes_into_conv remove_nodes(input_value.name) File "/workspace/libs/ONNX_Convertor/optimizer_scripts/tools/fusing.py", line 1007, in remove_nodes g.node.remove(input_weight) ValueError: Item to delete not in list
the code to convert is:
import ktc
import onnx
import torch
import torch.onnx
import numpy as np, os, sys, re, json
# Load model
exported_m = onnx.load('yolox_s.onnx')
# Optimize the exported onnx object
# onnx2onnx
optimized_m = ktc.onnx_optimizer.onnx2onnx_flow(result_m, eliminate_tail=True)
# save converted
onnx.save(optimized_m, 'yolox_cvt.onnx')
# eval result
km = ktc.ModelConfig(51200, "0001", "730", onnx_model=optimized_m)
eval_result = km.evaluate()
print("\nNpu performance evaluation result:\n" + str(eval_result))
@Werner
Hi Werner,
Sorry for the late reply; I have confirmed the problem for you here.
These two APIs will have errors in the latest version (kneron/toolchain:v0.19.0) of the Kneron Toolchain for the model you are using.
# onnx2onnx
You can try using Kneron Toolchain v0.17.2 when using these two APIs
docker run --rm -it -v /mnt/docker:/docker_mount kneron/toolchain:v0.17.2Other actions (e.g., eval result) are used in the latest version of the Kneron Toolchain (kneron/toolchain:latest).
docker run --rm -it -v /mnt/docker:/docker_mount kneron/toolchain:latest# eval result
