How Can I fix "new device is high" in KL630
When I connect my KL630 via USB, sometimes the text appears infinitely, as shown in the image above.
How Can I fix it?
  • Hi Seongyun,
    We've never encountered this situation. Could you describe in detail how you connected your KL630 via USB so we could try reproducing the error? Thanks!
  • edited January 2025
    @Maria Chen
    Hi Maria Chen!
    Thank you for your support
    When I connected KL630 via USB and power connecter. But The error appears Infinitely..
    I think that it usually appears when rebooting the KL630 models, then crash the USB connection codes and other codes.
    I don’t know any other reasons.
    I found only one solution. It’s just power connecter unplugged about 1minutes. And re-plugged KL630.
    Thank you!
  • Hi seongyunpark,
    Please try updating the firmware of the 96board again to see if the issue persists.
    Detailed instructions on how to update the firmware can be found in the KL630_96board_User_Manual document.
