Issue about converting onnx file to the nef file
I want to convert my own onnx model file into the nef file by using the example provided in the document center (YOLO example)
After I installed and entered the docker environment, tried to run the onnx2nef.py, but only got this error
And the environment is UBUNTU 20.04.2
Hi mint,
your onnx need some modification,
I guess you tried 3rd party tool for onnx conversion.
Please make sure your onnx could match the following spec.:
