KL720 在win10安裝完 Dependency 和 KDP2 Firmware , 但是 Kneron Academy 無法連接上webcam
可跑APP Inference Example
Add device failed , Connection failed
請問是哪邊的問題呢 ?
BRs,
Albert
  • 你是指這個?
    Kneron Academy 只支援KL520, 且如果KL520更新到KDP2 就無法用Kneron Academy
    Kneron Academy 無法連接上webcam ,這跟520/720無關,
    預設是使用cam "0" ,請確認你的webcam資源有沒有被占用
  • edited October 2021
    The webcam shows the video input normally in Academy , but when I press the connect button of Academy v1.2.1, it can't inference anything.
    The Academy windows always shows RED icon , I can't change anything of menu and the terminal message : Add device failed , Connection
    failed
    I used the Stem of USB Dongle ( KL720) , update to KDP2 .
  • Kneron Academy is only compatible with kdp structure (host_lib), KDP2(PLUS structure) cannot work with Academy.
    If you want use Academy, please update your firmware back to kdp fw.
