Program Flashing
I'm using KL720 SDK v1.3.0.
I have a question about Evaluation board(Board 96-B) setting.
I couldn't program flash via UART0 interface. Could you help me?
When I program flash via UART0 interface, which position of dip switch on the board is correct?
I tried it to be set UART mode. Is this setting correct?
I'm using binary code "flash_image_solution_companion.bin".
Below is the command which I tried.
>> python flash_programmer.py -a flash_image_solution_companion.bin
Could you give me advices?
switch to UART mode is correct
when run "python flash_programmer.py -a ... " you should get the message as picture:
what error message you got?
Thank you for your information.
I am using two environments, one is Ubuntu on Virtual Box and the other one is Msys2.
When I ran "python programmer.py a ..." on Ubuntu, there were some transfer errors.
When I ran "python programmer.py a ..." on Msys2, the error was "there isn't xmodem command".
I forgot to capture the message. I'll investigate them.
I resolved this problem.
I could flash the program by using native Ubuntu environment.
The problem was that previous environment didn't have enough tools for flashing.
I got a capture image.
