Inference code for testing docker toolchain example
Hi, I am able to write inference code for LittleNet model using ktc.kneron_inference and test it as well on my docker container but Now I want to write the inference code kl720 .
Can you please guide me to write inference code for the same model given in docker toolchain
Do I need to use kdp_wrapper for writing inference code for kl720??
Is it possible for write the inference code ktc APIs
Can you please answer
The easy way to test : use the https://github.com/kneron/host_lib KL720-yolo_public_example
I attach the files as zip file.
Abdullah_0001_112_112.bin is the input image in RGB565 format.
D:\Kneron\host_lib\host_lib-master\python>py main.py -t KL720-yolo_public_example
adding devices....
start kdp host lib....
Task: KL720-yolo_public_example
[array([[[[-13.31356977, 6.86266483]]]])]
de init kdp host lib....
I able to test successfully with your models_720.nef file but when I replaced it with my model ( /data1/batch_compile/models_720.nef ) which I compiled in toolchain I got the below results
will@will:~/New_project/kl720/host_lib-master/python$ python3 main.py -t KL720-littlenet_public_exampleadding devices....start kdp host lib....Task: KL720-littlenet_public_example[]de init kdp host lib....When I run the inferencing code for the same model in toolchain I get the below output
(base) root@edf75761b2af://workspace/william# python kl720_image_inference.py/workspace/miniconda/lib/python3.7/site-packages/numpy/__init__.py:156: UserWarning: mkl-service package failed to import, therefore Intel(R) MKL initialization ensuring its correct out-of-the box operation under condition when Gnu OpenMP had already been loaded by Python process is not assured. Please install mkl-service package, see http://github.com/IntelPython/mkl-servicefrom . import _distributor_initUsing TensorFlow backend.Section 3 E2E simulator result:[array([[[[-15.372369, 8.235198]]]])]Please let me whats the issue and how to fix it
could you upload your littlenet models_720.nef
This is the model I created
My model_id setting is 32768.
km = ktc.ModelConfig(32768, "0001", "720", onnx_path="/workspace/examples/LittleNet/LittleNet.onnx")
your model_id is 1001
So you need change model_id setting to 1001 in yolo_public_example.py
# Model ID is the same one generated with batch compile (32768 in this case)
#MODEL_ID = constants.ModelType.CUSTOMER.value
MODEL_ID = 1001
Its working now , Thanks
One things which I noticed was that while running using kl720 I am getting output as [array([[[[-13.31356977, 6.86266483]]]])]
and while running the inference code in docker toolchain the output is [array([[[[-15.372369, 8.235198]]]])]
Can you tell me why there is difference in value for the same model
In the KL720-yolo_public_example , input image using RGB565 color format (2 bytes per pixel).
The input data is similar with orginal picture but not same. So this example will get diferent output.
