Questions regarding testing /workspace/examples/LittleNet/LittleNet.onnx model on KL720
I have already created NEF file for Kl720 using /workspace/examples/LittleNet/LittleNet.onnx in the toolchain environment. Now I want to test the model on kl720.For this I want to write an inferencing code so I have a few questions
1) Do I need to use KDP wrapper , if yes what all APIs are needed
2) What is the difference between ISI mode and DME mode . Which mode to use for /workspace/examples/LittleNet/LittleNet.onnx model
3) What values should in use in model_id and image_cfg which is needed for kdp_wrapper.init_dme_config ? The model is /workspace/examples/LittleNet/LittleNet.onnx and the images used is /workspace/examples/LittleNet/pytorch_imgs/Abdullah_0001.png
/workspace/examples/LittleNet/pytorch_imgs/Abdullah_0002.png
/workspace/examples/LittleNet/pytorch_imgs/Abdullah_0003.png
/workspace/examples/LittleNet/pytorch_imgs/Abdullah_0004.png
I had already posted some of the questions in kl720 forum but didn't get any response so posting it here.
Please answer my queries
  • I post a comment for littlenet test at the 720 forunm .
    The littlenet is just a example for toolchain model convert.
    Yolo example is a more better to learn kneron APIs.
    1. kdp_wrapper is necessary for python example
    2. 720 not support dme mode now, 720 use isi_load_model to replace dme. Anyway ,use isi_load_model to put model in ddr, or use update_nef_model to put model in Flash. Two way could work for model inference.
