Input format is RGBA by config or by default, but input channel larger than 4
I was trying to run a complicated model on Kneron dongle, which had a lot of unsupported layers in the middle. I decided to split the model in the middle and run the two parts separately.
However, when I try to convert the second model (tflite), which uses feature map output from first model as input, the converter gives an error
Hardware not support: Input format is RGBA by config or by default, but input channel larger than 4
The input is a feature map with shape (1, 56, 56, 256).
Is the hardware not support channels more than 4 or it was thinking the input is an image?
Can I configure it to accept feature map input?
I'm using the python docker toolchain.
Thanks
Our solution currently does not support channels more than 4 .
You can provide information about your unsupported layers for us to see how we can help you
