KL720 dongle deploy on RK3399 problem
I already finish building PLUS, but appears the following problem.
admin@rk3399:~/src/kneron_plus/python/example$ sudo python3 KL720DemoCamAppYoloInference.py
 File "KL720DemoCamAppYoloInference.py", line 15, in <module>
  from utils.ExampleHelper import get_device_usb_speed_by_port_id
 File "/home/admin/src/kneron_plus/python/example/utils/ExampleHelper.py", line 12, in <module>
  import kp
 File "/home/admin/.local/lib/python3.6/site-packages/kp/__init__.py", line 5, in <module>
  from .KP import *
 File "/home/admin/.local/lib/python3.6/site-packages/kp/KP.py", line 5, in <module>
  from .KPCore import KPCore as core
 File "/home/admin/.local/lib/python3.6/site-packages/kp/KPCore.py", line 5, in <module>
  from .KPWrapperUtils import KPWrapperUtils as wrapper_utils
 File "/home/admin/.local/lib/python3.6/site-packages/kp/KPWrapperUtils.py", line 9, in <module>
  class KPWrapperUtils:
 File "/home/admin/.local/lib/python3.6/site-packages/kp/KPWrapperUtils.py", line 10, in KPWrapperUtils
  __KP_WRAPPER = KPWrapper()
 File "/home/admin/.local/lib/python3.6/site-packages/kp/KPBaseClass/WrapperBase.py", line 16, in __call__
  instance = super(Singleton, cls).__call__(*args, **kwargs)
 File "/home/admin/.local/lib/python3.6/site-packages/kp/KPWrapper.py", line 23, in __init__
  super(KPWrapper, self).__init__(lib_loader=KPLibLoader())
 File "/home/admin/.local/lib/python3.6/site-packages/kp/KPBaseClass/WrapperBase.py", line 25, in __init__
  self._load_libKSI()
 File "/home/admin/.local/lib/python3.6/site-packages/kp/KPBaseClass/WrapperBase.py", line 33, in _load_libKSI
  ctypes.CDLL(share_lib, mode=ctypes.RTLD_GLOBAL)
 File "/usr/lib/python3.6/ctypes/__init__.py", line 348, in __init__
  self._handle = _dlopen(self._name, mode)
OSError: /home/admin/.local/lib/python3.6/site-packages/kp/KPBaseClass/../../kp/lib/libusb-1.0.so.0: cannot open shared object file: No such file or directory
  • edited December 2021
    admin@rk3399:~/src/kneron_plus/python$ sudo bash install_libusb.sh
    root is not in the sudoers file. This incident will be reported.
    I sure I have this file, and I already "chmod it.
    Last article, I install "kneron_plus/python/package/ubunut".
    Now I install "kneron_plus/python/package/raspbianpi4", the following that.
      import kp
      from .KP import *
      self._load_libKSI()
    OSError: /home/admin/.local/lib/python3.6/site-packages/kp/KPBaseClass/../../kp/lib/libusb-1.0.so.0: wrong ELF class: ELFCLASS32
  • 安裝libusb步驟有問題, "root is not in the sudoers file"網路可以找到權限問題討論
  • 正確install_libusb.sh後,也會建立/etc/udev/rules.d/10-local.rules檔案
    就不須使用sudo來執行範例範例
    python要確定有安裝以下套件
    $ pip list
    KneronPLUS       1.2.1
    KneronPLUS-YOLO    1.2.1
    opencv-python     4.5.4.60
  • 不好意思 我來插花問一下
    RK3399本身的NPU 搭上 KL720 加成的效果如何 ?
    謝謝^^
