How to setup inference environment on the Raspberry pi 3 with Mini-AI-520
I got the Raspberry pi 3B+ with Mini-AI-520 and how to setup inference environment on it ?
I run the Kneron_DFUT but got error message below:
pi@raspberrypi:~/Downloads/Kneron_DFUT $ sudo ./KneronDFUT.sh
./KneronDFUT: 5: Syntax error: ")" unexpected
Is there any inference document or github for Mini-AI-520 ?
Hi Albert,
Unfortunately, the current Kneron_DFUT (v1.2.0) only supports Raspberry Pi 4, Windows, and Ubuntu.
There will be a new version of Kneron PLUS, estimated to be released at the end of the month. In that version, there will be a file you could use to build a binary executable file that should work on the OS you are using.
