Can use lookup table on KL520?
I want to use lookup table on KL520.
Is lookup table work on KL520?
Which .py should be change if I want to put it into hardware?
There are a few ways you could implement lookup tables, but it depends on your environment.
How are you planning to use the lookup table? Are you planning to use Kneron PLUS?
I don't need to use lookup table now.
Thanks for your response.
I want use lookup tabel as sigmoid at post-processing.
