KL720 initialize Flash failed
I used example "spi_master" and would load model from Flash to do inference.
And, when calling kdev_flash_initialize function, it occurred reading flash data failed, as the below
Load SCPU from flash image0: 0x00040000
LOG_ERROR: kdev_flash_read_BBM block 1023 reports status fail 0x1
LOG_ERROR: kdev_flash_read_BBM block 1022 reports status fail 0x1
========Magic number is 0xaaaaaaaaaaaaaaaa========
==boot from External Flash==
LOG_CRITICAL: ECC ERROR and CAN'T be CORRECTTED!
PLEASE ERASE and REPROGRAM FLASH to recover this critical issue!! address 0x260000 0x1
PLEASE ERASE and REPROGRAM FLASH to recover this critical issue!! address 0x4A0000 0x1
But, I loaded F/W of the example "solution_kdp2" to SCPU and no such kind of error occurred.
Does there exist some setting for memory configuration of project?
  • Hi Jack,
    Are you using the examples in the example_xxx folders (e.g. example_kdrv and example_sbt) in the firmware/build folder?
    If so, our examples can only use J-Link to load the firmware to DDR right now unless you modified them, since they're just examples. The solutions (in solution_xxx folders) can be loaded without errors.
