kneron-mmdetection on KLM5S3
in the kneron document center
I did the same with kneron-mmdetection step-by-step.
(https://doc.kneron.com/docs/#model_training/OpenMMLab/YoloX/)
The model trained in Kneron was downloaded and used. (https://github.com/kneron/Model_Zoo/raw/main/mmdetection/yolox_s/latest.zip)
As a final result, /data1/batch_compile/models_630.nef was created.
On the Vatics Evaluation Board (KLM5S3 SiP EVM)
The nni_generic program was executed by changing config (nni_generic_config.ini) as follows.
   Mode = 0
   Model_Path="./Resource/models/models_630.nef"
When viewed with VLC Media player
A green box is drawn randomly regardless of the object.
I don't know which step is wrong.
    Thank you for the question.
    Regarding KLM5S3 related question, could you contact these people directly?
    Nick.Wang <nick.wang@vatics.com>; Jack.Zhan <jack.zhan@vatics.com>; Max.Chang <max.chang@vatics.com>;Benjamin.Wang<benjamin.wang@vatics.com>; Shihchun.Fanchiang <shihchun.fanchiang@vatics.com>
    Nick Wang will be the main contact in this group.
  • Hi warren
    Thank you very much.
    I'll ask Vatics directly.
    Thanks again.
