preprocess and quantization error
I am trying to deploy my facial landmark detection model into the KL520 device.
My model takes input value between [0,1], so I set img_preprocess_method as "yolo" in my input_params.json as following.
{ "model_info": { "input_onnx_file": "/data1/tf_test/lm_pad_mask_64_0921.tflite.opt.onnx", "model_inputs": [{ "model_input_name": "input" , "input_image_folder": "/data1/tf_test/img_rgb" }] }, "preprocess": { "img_preprocess_method": "yolo", "img_channel": "RGB", "radix": 7, "keep_aspect_ratio": true, "pad_mode": 1, "p_crop": { "crop_x": 0, "crop_y": 0, "crop_w": 0, "crop_h": 0 } }, "simulator_img_files": [{ "model_input_name": "input" , "input_image": "/data1/tf_test/img_rgb/1_112_112.jpg" }] }
However, when I run the generated all_model.bin and fw_info.bin using dme_keras.py, I found the inference result is quite different from my original model.
Kneron Device: [0.35792017 0.27688164 0.3174009 0.8576578 0.46597153 0.45921832 0.66181463 0.27012843 0.6348018 0.77661926] TFlite: [0.26855683 0.23025376 0.2584893 0.6576536 0.4441332 0.36857533 0.62811494 0.28813866 0.62961656 0.6005157 ]
I use the same dme cfg setting as kdp_dme_load_yolo_model.
# dme configuration model_id = 1000 # model id when compiling in toolchain output_num = 1 # number of output node for the model image_col = 64 image_row = 64 image_ch = 3 image_format = (constants.IMAGE_FORMAT_SUB128 | constants.NPU_FORMAT_RGB565 | constants.IMAGE_FORMAT_RAW_OUTPUT)
I am wondering whether my image_format setting is wrong, so my model takes the wrong value range as input or the difference of inference result is just quantization error.
I think because you select yolo [0-1] as your input pre process, so you have to modify the dme configuration. You should modify the image_format to the following:
image_format = (constants.IMAGE_FORMAT_RIGHT_SHIFT_ONE_BIT |
it means you right shift 0-255 by 1 bit, so it would means 0-1 in 8 bit fixed point. Remember the MSB is sign bit. Please give it a try and let us know if it leads to better result. Thanks,
Thank you for your reply and help.
The inference result became more reasonable after I use "constants.IMAGE_FORMAT_RIGHT_SHIFT_ONE_BIT".
But, I still met some problems with the preprocessing, when I am trying to convert other models using the toolchain 520.
I am not sure what those constants and preprocess functions actually do on the device.
Is there any documentation writing about it?
If I use IMAGE_FORMAT_RIGHT_SHIFT_ONE_BIT, the value of input will be divide by 2, so the value range is [0,128].
Supposedly, it will then divided by 2^7 to make it [0,1] on the device. But, where to set this 2^7 value?
Also, I am trying to convert a model that takes input range as [0,255] directly.
I made a customized preprocess method in img_preprocess.py to return x without doing any normalization method.
but it failed when executing fpAnalyserCompilerIpevaluator_520.py.
Can the quantization tool and demo API handle the model with input range [0,255]?
For your question:
When you set the input_params.json, you already tell the hardware radix at 7, this means the decimal point is set to before the 7th bit of the 8 bits value.
for example, the white pixel in 0-255 is 255, and after you do the right shift to 1 is 127, which is 0111_1111 in 8 bits. And since you have let the hardware know the input radix is 7, this means the decimal point at 0.111_1111=1-1/127= 0.992 -> the input range is [0-1]
If you want to set the input range to [0-255], you still need to do right shift because the 8th bit is a sign bit, so it cannot be 1, because that would mean the number is a negative number. for 0-255, you need to set the radix to be -1 in input_params.json in order to make it work. radix -1 means where the decimal point at. -1 means the bit 0 actually stands for 2.
