how can I compile onnx model to nef with input format BGR565?
Hello, I used "kneron/toolchain:v0.19.0", and I try to compile model,not YOLO like depth estimation or deburring model.
If I run the nef model on the chip after a successful compilation, the results are very different.
(However, nef's output using kneron_inference() looks good.)
I'd like to check if the cause is in the input format or not.
The nef model I compiled has rgb888 as the input image format.
So how can I compile onnx model to nef with input format BGR565?
I have to use the toolchain version 0.19.0 and the non-Yolo model.
Hi Hyun,
You asked a similar question before. Please refer to the answer here:
how can I compile onnx model to nef with input format BGR565? — Kneron Developer Forums
