run with KL720 on VM but got error
Hi, I tried to build code on Virtual Machine Ubuntu 18.04.
cd kneron_plus/ mkdir build cd build cmake -DWITH_DFUT=ON .. make -j
After building successfully, tried to run scan_devices.
ytl@ubuntu:~/kneron_plus_v2.3.0/kneron_plus/build/bin$ ./scan_devices scanning kneron devices ... number of Kneron devices found: 1 listing devices infomation as follows: [0] scan_index: '0' [0] port ID: '4' [0] product_id: '0x720' (KL720) [0] USB link speed: 'Super-Speed' [0] USB port path: '4-1' [0] kn_number: '0xAB062D4C' [0] Connectable: 'True' [0] Firmware: 'KDP2 Comp/F'
But when I ran generic_command, I got the error.
ytl@ubuntu:~/kneron_plus_v2.3.0/kneron_plus/build/bin$ ./generic_command -t KL720 [note - using default parameter values if no value is passed] -target: [target platform] (KL520, KL720, KL630, KL730, KL830) = KL720 (default: KL520) -sidx : [scan index] = default (specified scan index) (default: scan index of the first scanned Kneron device) -port : [port id] = default (specified port id) (default: port ID of the first scanned Kneron device) Notice that scan index has higher priority than port id -cmd : [command type] (system-showSystemInfo, model-showModelInfo, reboot, shutdown) = default (default: system) Notice that the shutdown command is only supported by KL520 96 board connect target: index '0', port ID '4' connect device ... OK getting system info error, error code: -7 PLUS_version: 2.3.0 disconnecting device ...
My question is why scan_devices shows no problem, but generic_command shows a connected error.
Could you please help me?
Thanks in advance!
Sometimes, when you're using a virtual machine, you might need to make sure that your KL720 device (dongle/board) is connected to your virtual machine instead of your computer. What virtual machine software are you using? Are you using a KL720 dongle or development board? Also, have you loaded KL720 firmware on your device?
