Yolo v4 on KL520?
Yolo v4 was published for several months
https://arxiv.org/abs/2004.10934
with source code
https://github.com/AlexeyAB/darknet
Was it possible to run v4 on KL520?
Can I simply replace v3 example code by v4 source code? or some modify?
thanks.
v4 example code can replace v3,
Hi Bob,
If you take a look at the op support list in our document center, you will find that there are some op in Yolo v4 that KL520 doesn't support, especially the activation layer. You can replace those activations with the one that we support, such as leaky Relu.
