How to rotate UI and Video image in 90 or 270 degree in KL730
Because the lcd panel only supports in portrait mode, I would like to rotate the image or video using the available API.
I've found that ISP module has rotation option, so I've tried using the API: VMF_ISP_Init , VMF_ISP_SetOption, VMF_ISP_Process. But the VMF_ISP_STATES_T.bFrameDone is always 0.
Meanwhile, Resize API works with no problem.
Is there any API that supports rotation in standalone way like independent of active video streaming?
Thanks in advance!
  • Hi Coben,
    Regarding more in-depth questions on KL730, please contact your dedicated sales representative (the person you bought it from). They will coordinate with our technical team to assist you further. Thank you!
