KL730 SDK 2.0.0 – Custom YOLO11 NEF Works via USB but Standalone Inference Returns KP_ERROR_INVALID_
We are testing a custom YOLO11 phone-detection model on the KL730 Evaluation Board using SDK 2.0.0.
The model works successfully through USB customized inference, but standalone inference directly on KL730 Linux fails with KP_ERROR_INVALID_MODEL_21.
Environment:
  • Board: KL730 EVM
  • SDK: 2.0.0
  • Firmware: 0.0.0.515
  • Model ID: 32769
  • Input: RGB565, 640 × 640
  • Output tensors: 2
Test Results:
NEF loading: 0
Model ID: 32769
Registered model output tensors: 2
FIFO allocation: 0
Image enqueue: 0
VMF_NNM_Inference_App_Execute model=32769
Inference return code: 21
Questions:
  1. Does KL730 SDK 2.0.0 officially support running custom NEF inference directly from a standalone Linux ARM64 executable?
  2. Why does VMF_NNM_Inference_App_Execute() return Error 21 even though the NEF loads successfully?
  3. Does standalone inference require additional initialization, firmware configuration, or a specific boot mode?
  4. Is there an official example for running custom NEF inference directly on KL730 Linux?
Please suggest the officially recommended workflow.
Thank you.
