Compiler Issue for yolov5s
I would like to compile yolov5s model to have the bin files by using your tool. The model is modified and can be transferred as onnx format. However, in compiler step, I get one issue as follows msg. It shows these is a undefinedCpuOpt in my sigmoid function. How to fix it?
Jerome
(env_CPU) (base) ⚙ k-toolchain@AI-Train-1 ~/kneron/workspace/toolchain_520 python scripts/fpAnalyserCompilerIpevaluator_520.py -t 8 -c model/input_params.json
input = /home/k-toolchain/kneron/workspace/toolchain_520/.tmp/updater.json
Now loops 1 time ]3% 0.000000s
Now loops 2 time===> ]26% 0.002000s
Now loops 3 time======> ]30% 0.003000s
Now loops 4 time===============> ]43% 0.005000s
Now loops 5 time================> ]44% 0.005000s
Now loops 6 time====================> ]50% 0.007000s
Now loops 7 time=====================> ]52% 0.007000s
Now loops 8 time======================> ]53% 0.007000s
Now loops 9 time==============================> ]64% 0.011000s
Now loops 10 time=====================================> ]75% 0.013000s
Now loops 11 time========================================> ]80% 0.014000s
Now loops 12 time================================================> ]92% 0.016000s
Now loops 13 time====================================================> ]98% 0.018000s
Now loops 14 time======================================================]100% 0.018000s
Done!
[piano][warning][graph_gen.cc:85][GenerateGraph] Model [/home/k-toolchain/kneron/workspace/toolchain_520/model/fpAnalyser/best.opt.quan.wqbi.bie] is BIE, skip optimization config
terminate called after throwing an instance of 'UndefinedCpuOp'
what(): Undefined CPU OP: Undefined CPU op [Sigmoid] for layer [Sigmoid_1]
File "scripts/fpAnalyserCompilerIpevaluator_520.py", line 46, in <module>
run_compiler_520(bie_file)
File "/home/k-toolchain/kneron/workspace/toolchain_520/scripts/utils/run_compiler_520.py", line 26, in run_compiler_520
subprocess.run([LIBS_FOLDER + '/compiler/compile_mozart',
File "/home/jerome/anaconda3/lib/python3.8/subprocess.py", line 512, in run
raise CalledProcessError(retcode, process.args,
subprocess.CalledProcessError: Command '['/home/k-toolchain/kneron/workspace/toolchain_520/libs/compiler/compile_mozart', '/home/k-toolchain/kneron/workspace/toolchain_520/model/fpAnalyser/best.opt.quan.wqbi.bie', '/home/k-toolchain/kneron/workspace/toolchain_520/.tmp/config_compiler.json', 'warning', 'compile.log']' died with <Signals.SIGABRT: 6>.
HI,
We 520 not support sigmoid function, so you need remove sigmoid function.
need to remove sigmoid function which is inside yolo5s model.
Hi Jennifer,
Roger that, thanks!
Jerome
