[Bug] Wrong script path in /workspace/scripts/convert_model.py in latest toolchain docker image
Docker image ID: 0923a4d61021
When converting TFLite to ONNX with the scripts in example (`python /workspace/scripts/convert_model.py tflite path_of_input_tflite_model path_of_output_onnx_file`)
Got message:
python: can't open file '/workspace/libs/ONNX_Convertor/optimizer_scripts/tflite-onnx/onnx_tflite/tflite2onnx.py': [Errno 2] No such file or directory Traceback (most recent call last): File "/workspace/scripts/convert_model.py", line 84, in <module> '-release_mode', 'True'], check=True) File "/workspace/miniconda/lib/python3.7/subprocess.py", line 512, in run output=stdout, stderr=stderr) subprocess.CalledProcessError: Command '['python', '/workspace/libs/ONNX_Convertor/optimizer_scripts/tflite-onnx/onnx_tflite/tflite2onnx.py', '-tflite ', <TFLite file>, '-save_path', <ONNX file>, '-release_mode', 'True']' returned non-zero exit status 2
The problem is the redundant /optimizer_scripts in the path.
However, after remove the path, the script still fails, message:
tflite2onnx.py: error: unrecognized arguments: -tflite /data1/char_mobilenet_1.0_128_20180515_unquant.tflite Traceback (most recent call last): File "/workspace/scripts/convert_model.py", line 84, in <module> '-release_mode', 'True'], check=True) File "/workspace/miniconda/lib/python3.7/subprocess.py", line 512, in run output=stdout, stderr=stderr) subprocess.CalledProcessError: Command '['python', '/workspace/libs/ONNX_Convertor/tflite-onnx/onnx_tflite/tflite2onnx.py', '-tflite ', <TFLite file>, '-save_path', <ONNX file>, '-release_mode', 'True']' returned non-zero exit status 2.
This problem is caused by the trailing white in line 84:
'-tflite ', args.input_model,
After removing the space after tflite , the script works.
Diff:
--- convert_model.py.orig 2021-04-19 07:42:23.604756103 +0000 +++ convert_model.py 2021-04-19 07:53:22.764785209 +0000 @@ -78,8 +78,8 @@ args.input_model, args.output_model], check=True) call_optimizer(args.output_model, args.output_model, args.disable_fuse_bn) elif args.platform == 'tflite': - subprocess.run(['python', CONVERTER_BASE + '/optimizer_scripts/tflite-onnx/onnx_tflite/tflite2onnx.py', - '-tflite ', args.input_model, + subprocess.run(['python', CONVERTER_BASE + '/tflite-onnx/onnx_tflite/tflite2onnx.py', + '-tflite', args.input_model, '-save_path', args.output_model, '-release_mode', 'True'], check=True) call_optimizer(args.output_model, args.output_model, args.disable_fuse_bn)
I haven't check other paths, so you may want to double check the script again, thank you.
Hi Phidias,
Really thanks your post,
we will fix this bug in next release.
