How to setup the member ext_param of Structure kdp_dme_cfg_s ?
There is a attachment about code.
I can't upload cpp file, so the file is txt.
Code is almost as same as kneron sample code.
Difference is line 30 (original input name is dog, but I change to cat) and line 233 (I try to modify threshold).
Cat image and model source is from kneron sample code. (v0.9.1)
if user id is 0, detection result:
If user id is 1,
There are 2 question.
Q1: I have setup line 233:
dme_cfg[1].ext_param[0] = 0.01f;
Doesn't it means my minimum threshold is 0.01 ?
Why not working? How to correct it?
Q2: What's the yolo threshold mapping to ext_param index?
In host_lib/example/KL720/post_processing_ex.c
line 35 and 36 are 2 different threshold to define final detection result.
line 39 and 41 are 2 anchors to calculate rectangle size.
so, how to setup 2 threshold and anchor size to ext_param?
Hi, sir,
how does you mAP result?
the threadhold setting would be follow the detection result.
suggest to set class with 1 or 2 class in order to check the relation with thread.
