problems when getting started to use kl720 device according to the documents
I have downloaded the opencv through MSYS2 and done all the step in the document, but this occured when I was trying to make the examples.
There is also a problem when I try to execute one of the examples by this "sudo ./kl520_demo_generic_image_inference_post_yolo" command line, it shows that "# sudo ./kl720_demo_generic_image_inference_post_yolo
-bash: sudo: command not found "
I am using the MSYS2 on windows.
Hi Jingyuan,
The OpenCV issue you asked in the other thread has been answered, but you could check if you've followed the instructions on this documentation (for Windows): Install Dependency - Document Center (kneron.com)
About the command not found issue, the command "sudo ./kl720_demo_generic_image_inference_post_yolo" is for Ubuntu. The correct command for MSYS2 on Windows is:
