如何跑SDK中的demo code "solution_kdp2_hico_mipi"?
我们购买了development Kit (KL720_DMB_BGA386_SCHEMATIC_VOP2)。之后想学习一下怎么把它跑起来,下载了SDK,查看到有solution_kdp2_hico_mipi这个例子,但是目录中只有SCPU的代码,不知道NCPU也是下面说1-3步中是怎么做的,为了跑这个demo有相对应的NCPU例子吗?
Below is a recommended flow of AI application construction:
- Prepare your AI model(s)
 - Convert and verify model(s) via Kneron Toolchain
 - With a PC, it is convenient to verify converted NEF models and easy to test variant data on target device via Kneron PLUS
 - note: If your application is designed as host-companion architecture with USB interface, you can stop here and go ahead with Kneron PLUS.
- See Kneron PLUS - generic inference for model-only verification
 - See Kneron PLUS - customized API for model and pre/post process function implementation.
 - Replace implementation of data Input and result output flow according to application requirement if your application is not designed as host-companion architecture. That's to replace the related code for data-in/data-out over USB interface which is designed for Kneron PLUS control protocol library by your implementation.
For example, to consider an application which requires a connected MIPI sensor to chip as image source and output result through UART interface.
After step 1-3, implementation of model inference flow and verification is done. Refer to the diagram below. The inference flow behind kmdw_inference_image_dispatcher_thread is verified and ready. All you have to do is to modify the firmware, solution_kdp2_user_ex, which is used with Kneron PLUS for model verification by replacing the threads for data/input and result/output to become a customized firmware. The implementation is easy by calling kmdw_fifiq_manager_XXX() APIs to arrange data flow for inference tasks.
要跑solution_kdp2_hico_mipi,會需要準備相對應的KL720板子(KL720_DMB_BGA386_SCHEMATIC_VOP2)與Hico MIPI camera。
如果沒有Hico MIPI camera,可以先跑Kneron PLUS的基本範例。Kneron PLUS有提供範例模型可以直接使用。
您可以在Kneron的網站下載Kneron PLUS,然後用現有的firmware (SCPU跟NCPU)來跑範例。
下載網址: 开发中心 | Kneron - 人工智能无处不在
燒錄firmware方法(KL720): Getting Started - Document Center (kneron.com)
Firmware path:
Maria Chen,非常感谢你的回复,我们已可以在PC跑你们的dongle 的demo了,这个应就是你说的Kneron PLUS吧,对吗?Kneron PLUS是通过PC的USB作为数据输入
是的,Kneron PLUS是通過PC的USB做輸入的。
如果後續有任何問題,請再跟我們說,謝謝!
Maria Chen, 我们购买了KL720板子(KL720_DMB_BGA386_SCHEMATIC_VOP2)。 还要再买一个Hico MIPI camera才可以跑上面的demo是吧。如果我们买好了Camera后怎么跑demo code呢,SDK中只有SCPU的代码,没NCPU的
是的,會需要Hico MIPI camera。Firmware的SCPU需要自行去build,而NCPU照理上可以直接使用Kneron PLUS裡面的NCPU。
我們有Kneron PLUS Enterprise (含有Hico MIPI的demo code) 開放給特定的客戶,如果有需要開放權限可以向我們的業務窗口詢問與申請。
Enterprise的範例demo: Run Examples for Enterprise - Document Center (kneron.com)
Hi Maria,我下载了 KL720_SDK_2.1.0 。 里面有个MIPI的demo, 这个SDK的demo跟Kneron PLUS Enterprise (含有Hico MIPI的demo code) 里面的demo是不同的?
KL720 SDK的solution_kdp2_hico_mipi與Kneron PLUS Enterprise的HICO Camera Inference demo是相對應的。
要跑HICO Camera Inference,會需要build在KL720 SDK裡面的solution_kdp2_hico_mipi,生成firmware燒進KL720板子,才可以讓Kneron PLUS Enterprise裡面的HICO Camera Inference demo成功執行。
Maria, 我理解到的KL720有两个内核SCPU和NCUP,KL720 SDK裡面的solution_kdp2_hico_mipi是SCPU的代码。如果说KL720 SDK的solution_kdp2_hico_mipi與Kneron PLUS Enterprise的HICO Camera Inference demo是相對應的。可以理解为Kneron PLUS Enterprise的HICO Camera Inference demo是跑在NCPU吗?我们下周有一个会议和你们沟通,到时他们可能谈商务上如何申请访问权限。
是的,KL720的firmware有SCPU和NCPU。KL720 SDK的solution_kdp2_hico_mipi裡面SCPU和NCPU都有包含。Kneron PLUS的res/firmware裡面已有的fw_scpu.bin和fw_ncpu.bin都是在KL720 SDK裡面build好的。
Kneron PLUS是一個我們可以用Kneron的產品跑inference的介面,要跑這些inference demo會需要有Kneron的產品(dongle, board, etc.)、firmware (scpu和ncpu)、model才可以跑。
這個網址有詳細解釋Kneron PLUS與firmware: Introduction - Document Center (kneron.com)
可是我看到下载的SDK的MIPI示例NCPU里面是空的
KL720 SDK裡面有包含SCPU與NCPU,但是NCPU的project位置並不是直接放在solution_kdp2_hico_mipi裡面。
Maria Chen, 你说在别的地方,是要我早请到权限之后才能看到NCPU的例子吗?如果不是在MIPI同一个目录下
除非有用自己的模型的需求,一般來說NCPU不需要做改動。您要跑HICO Camera Inference Demo的話,可以直接使用在PLUS裡面已有的fw_ncpu.bin,不需要額外去build NCPU。
如果要編輯或build NCPU,會需要跟我們的業務窗口申請開放權限,也需要有DSP (Xtensa Xplorer)的授權。
hi Maria, 那如果我直接用PLUS裡面已有的fw_ncpu.bin,我们要把识别的物体的数据发给另个MCU(比如用IIC去发给另一个MCU),是不是在SCPU里拿到识别的数据加上IIC通讯就可以发过去了?
是的,要把識別的物體的數據(inference的結果)發給另一個MCU,會需要自行加上IIC通訊,還有模型需要用我們NCPU支援的模型,理論上就可以發過去了。
