Load two models nef into KL720
My platform:
++ USB dongle
++ plugin to my board.
1. I try to load two models into KL720 but the result are fails.
Do we load two models on USB KL720 ?
2. I also try to combine two nef model into one models by command:
./kneron_nef_utils --combine_nef path/to/file_A.nef path/to/file_B.nef
Although the result is finish, but can see file_A.nef , i use command:
./kneron_nef_utils --info path/to/file.nef
Could you help us how to combine two nef models ?
Please refer to the following description for your question.
Thank for your support!
//The issue with NEF combining occurred previously due to a toolchain version conflict.
//You can try using the latest version of the toolchain to re-generate the NEF models and combine them again. If the issue persists, please provide both NEF files for debugging.
Yes, i also try to re-generate two NEF models, then combine them again. But only see the first NEF model.
Could you help to review the issue ?
I attached two nef models.
Thank very much.
Hi Tri,
The NEF files can't be combined because the versions of the NEF files are different: one is v0, and the other one is v1. You could check the versions of the NEF files with:
./kneron_nef_utils --info path/to/file.nefTo resolve this, you could edit the flatbuffer to False in batch compile to disable flatbuffer mode so that it compiles v0 NEF files.
(You may use either ktc.compile or ktc.encrypt_compile)
Then, you should be able to combine both v0 NEF files.
Reference: 5. Compilation - Document Center (kneron.com)
Thank for your support.
We are using two nef modesl to combine, and if we use onnx to combine model, We do not have onnx of "yolov5_pd/models_720.nef"
Could you help us where do we get the onnx of the model below ?
+ kneron_plus_v2.1.1/kneron_plus/res/models/KL720/yolov5_pd/models_720.nef
Thank you very much.
Hi Tri,
The model "yolov5_pd/models_720.nef" is trained by Kneron. We provided the NEF file as an example for users, but we will not release the original ONNX model.
If you want to train the yolov5/v7 model yourself, you can refer to the modifications discussed in the following link: https://www.kneron.com/forum/discussion/comment/1421/#Comment_1421
NEF Header:
platform:
target: 720
crc: 0xE2D6AFDB
kn_number: 0x0
encryption_mode: NONE
compiler_version: v0.9.1(befccbd0f)
toolchain_version: kneron/toolchain:v0.23.1
schema_version: v0.0.1
uuid: 0xE2D6AFDB
solution_id:
solution_tag:
NEF Model Info:
Model_ID: 2
Model_Name: input.kdp720.scaled.bie
Model_Version: 0x2
Model_ID: 1
Model_Version: 0x1
This is model i combine:
I try to use kp_generic_raw_inference_send successful only "Model_ID: 2",
If i change "_input_desc.model_id = 1", kp_generic_raw_inference_send is fail. this is parameter i use:
_input_desc.model_id = 1;//_model_desc.models[0].id; // first model ID
_input_desc.resize_mode = KP_RESIZE_ENABLE; // enable resize in pre-process
_input_desc.padding_mode = KP_PADDING_CORNER; // enable corner padding in pre-process
_input_desc.normalize_mode = KP_NORMALIZE_KNERON; // this depends on models
_input_desc.image_format = KP_IMAGE_FORMAT_RGBA8888; // image format
_input_desc.width = pFrameBuffer->width; // image width
_input_desc.height = pFrameBuffer->height; // image height
_input_desc.inference_number = 0; // inference number, used to verify with output result
_input_desc.crop_count = 0; // number of crop area, 0 means no cropping
Do we have any wrong ?
Hi Tri,
It might be hard to debug with only the information above. Could you provide us with your NEF files and the program file you're running, so we could look into them? Thanks!
