KL720 power pin decouping and filter
Dear Sir,
I have some questions regarding to power domain and power decoupling, filtering:
1/ If I do not use the USB 2.0 interface, Could I not supply power and decoupling capacitors for USB 2.0 power pins? Same for interface in bank 3?
2/ Using the Ferrit bead to isolate between power rails is needed, right? But Figure 3 - Power topology: KL720 bypass capacitors in the KL720 HW design guide v0.2, do not show the ferrite bead between power rails. Could you say me what is right/recommended?
In demo board design
