Kneron AI-KL730
我在kl730模型开发的时候遇到了问题,就是我的.onnx转.nef模型的时候,工具链v.30.0版本是modelconfig增加了一个可选参数 input_fmt用于指定模型输入格式,但我填入参数的 input_fmt="4W4C8B"的时候去进行转换,转换代码伪代码km = ktc.ModelConfig(211, "0001", "730", onnx_model=m, input_fmt="4W4C8B")。
总是有如下报错。
[common][error][exceptions.cc:41][KneronException] HardwareNotSupport: Unsupported ReFormat fmt [4W4C8B]
[common][info][utils.cc:271][DumpBacktrace] dump backtrace
Stack trace (most recent call last):
#10  Object "", at 0xffffffffffffffff, in
#9  Object "/workspace/libs_V2/compiler/batch_compile", at 0x5fecd2a925bd, in _start
BFD: DWARF error: section .debug_info is larger than its filesize! (0x93f189 vs 0x530e70)
#8  Object "/usr/lib/x86_64-linux-gnu/libc.so.6", at 0x70cc17576082, in __libc_start_main
#7  Source "/projects_src/kneron-piano_v2/compiler/bin/batch_compile/batch_compile.cc", line 375, in main [0x5fecd2a8da4f]
#6 | Source "/projects_src/kneron-piano_v2/compiler/bin/batch_compile/batch_compile.cc", line 174, in BatchCompile
  | Source "/projects_src/kneron-piano_v2/compiler/bin/batch_compile/batch_compile.cc", line 149, in RunCompile
   Source "/projects_src/kneron-piano_v2/compiler/lib/common/public/compile_impl.h", line 62, in Compile(char const*, char const*, Json::Value const&, FirmInfo*) [0x5fecd2a93197]
#5  Source "/projects_src/kneron-piano_v2/compiler/lib/wagner/backend/compile.cc", line 313, in CompileImpl [0x70cc167b079c]
#4  Source "/projects_src/kneron-piano_v2/compiler/lib/common/backend/compile_utils.cc", line 606, in GraphCompiler::OptimizeGraph() [0x70cc1685ca0b]
#3  Source "/projects_src/kneron-piano_v2/compiler/lib/wagner/frontend/tgt_graph_gen.cc", line 79, in GraphOptBE(Graph&, ShapeInferencer&) [0x70cc1681917e]
#2 | Source "/projects_src/kneron-piano_v2/compiler/lib/wagner/frontend/tgt_post_process.cc", line 163, in WagnerPostProcess(Graph&)
  | Source "/projects_src/kneron-piano_v2/compiler/lib/wagner/frontend/tgt_post_process.cc", line 138, in PostCheck
  | Source "/projects_src/kneron-piano_v2/compiler/lib/wagner/frontend/tgt_post_process.cc", line 87, in CheckReFormatFmt
   Source "/projects_src/kneron-piano_v2/piano/lib/piano/common/exceptions.h", line 50, in HardwareNotSupport::HardwareNotSupport(std::string const&) [0x70cc166bb825]
#1  Source "/projects_src/kneron-piano_v2/piano/lib/piano/common/exceptions.cc", line 44, in KneronException::KneronException(ErrorCode, std::string const&) [0x70cc17c9fd76]
#0  Source "/projects_src/kneron-piano_v2/piano/lib/piano/common/utils.cc", line 273, in DumpBacktrace() [0x70cc17cb79e8]
[tool][error][batch_compile.cc:175][BatchCompile] Failed to compile input.onnx
 File "/docker_mount/test_data/25_8_8.py", line 60, in <module>
  main()
 File "/docker_mount/test_data/25_8_8.py", line 56, in main
  nef_model_path = ktc.compile([km])
 File "/workspace/miniconda/envs/onnx1.13/lib/python3.9/site-packages/ktc/toolchain.py", line 519, in compile
  return encrypt_compile(
 File "/workspace/miniconda/envs/onnx1.13/lib/python3.9/site-packages/ktc/toolchain.py", line 661, in encrypt_compile
  subprocess.run(commands, check=True)
 File "/workspace/miniconda/envs/onnx1.13/lib/python3.9/subprocess.py", line 528, in run
  raise CalledProcessError(retcode, process.args,
subprocess.CalledProcessError: Command '['/workspace/libs_V2/compiler/batch_compile', '-T', '730', '/data1/kneron_flow/batch_compile_bconfig.json', '-t', 'kneron/toolchain:v0.30.0\n', '-o']' returned non-zero exit status 4.
  • edited August 2025
    KL730 如果要指定 input 是 4W4C8B,格式上需要滿足 conv 是 first layer, 且 input channel <=4 && column stride <= 2 && column dilation == 1
    onnx conv stride/dilation 定義可以參考 https://github.com/onnx/onnx/blob/rel-1.15.0/docs/Operators.md#conv
    若轉換4W4C8B會失敗且模型無法修改的話,可以再試試看下面兩種format
    https://doc.kneron.com/docs/#toolchain/manual_3_onnx/#32-ip-evaluation
    • 11: ("HW4C8B_DROP_A", 8),
    • 8: ("1W16C8B", 8),
    這兩種在FW上有特別處理,理論上也可以配合KL730的硬體使用
    • 11: ("HW4C8B_DROP_A", 8)也是转换失败,8: ("1W16C8B", 8)能转出models_730.nef模型成功,但是我放进plus v3.1.2进行模型推理,kp_customized_inference_send推理部分都是返回失败,inference failed, error = -1 (USB: Input/output error)。kp_generic_image_inference_send和kp_generic_data_inference_send虽然推理成功,但是并不能和models_730.nef转换前身.pth文件有一样的效果。我还需要哪些处理。
  • 如果我转换4W4C8B输入类型成功,是否都能适配plus接口和FW上的处理,无需做过多的修改,就能进行模型替换推理?
  • 要比較models_730.nef與pth,請先在toolchain上透過ktc.kneron_inference()分別對ONNX與NEF模型推論,並確認兩者使用完全相同的流程(preprocess, postprocess. etc..),僅有模型的差異,來比較兩者答案是否都有符合您的預期
    在因為PLUS上容易因為前後處理與原本有差異而導致結果不同,在toolchain上透過ktc.kneron_inference()能夠針對確認模型效果,使用方法請參考下面toolchain文件
    https://doc.kneron.com/docs/#toolchain/manual_1_overview/#12-workflow-overview
    另外,要使用kp_customized_inference_send來進行推論的話,必須事先透過SDK在FW中加入您的模型資訊與流程(model_id, job_id, preprocess, postprocess function, etc..),4W4C8B只是確保您的模型與KL730前處理IP的格式相符,對應的周邊流程還是要由您這邊自行開發
    相關使用方法可以參考文件
    https://doc.kneron.com/docs/#plus_c/feature_guide/customized_api/create_kl730_single_model_example/
  • 后续我使用最新版的YOLOX训练了一个自定义物体的模型,模型文件.pth和.onnx都经过YOLOX内脚本验证,单张图片推断得出结果可视化没有问题,后面我是用了kneron toolchain把onnx转成nef,转换脚本如下
    模型转换成功,每次kneron_inference也是有输出的,但我该如何从ktc.kneron_inference得出结果,制定后处理程序
  • @tstc
    Hi tstc ,
    關於 ktc.kneron_inference 的用法,可以把它理解為:呼叫這個 API 後,得到的輸出就是 model 的 raw output。
    您可以參考以下連結:
    https://doc.kneron.com/docs/#toolchain/manual_3_onnx/ (3.3. E2E Simulator Check (Floating Point))
    https://doc.kneron.com/docs/#toolchain/manual_4_bie/ (4.2. E2E Simulator Check (Fixed Point))
    https://doc.kneron.com/docs/#toolchain/manual_5_nef/#52-e2e-simulator-check-hardware (5.2. E2E Simulator Check (Hardware))
    您可以想成這三個的關係為,
    ONNX -> Floating Point [原始浮點的模型]
    BIE -> Fixed Point [量化後的模型]
    NEF -> Hardware [跑在 NPU 上的模型]
    您有提到以下
    "模型文件.pth和.onnx都经过YOLOX内脚本验证,单张图片推断得出结果可视化没有问题"
    換句話說,您可以將 ONNX 的 inf_result、BIE 的 fixed_results、以及 NEF 的 hw_results 都搭配相同的 pre/post-process,來進行單張圖片推論,並最終做可視化確認。
    至於具體的 pre/post-process 範例的話,您可以參考 https://doc.kneron.com/docs/#toolchain/appendix/yolo_example/#optional-step-7-check-nef-model
    但請注意,pre/post-process 必須依照您在 YOLOX 內建腳本驗證時所使用的流程來實作。
  • 您好,我想问一下,这个模型信息的量化参数quantization_parameter[0]是什么参数在影响他的基数和比例呢?我前后使用相同的数据集训练和相同的脚本转换,但是出来的nef模型,这个参数相差较大。
  • @tstc
    Hi tstc,
    關於此問題,我們已透過電子郵件與您聯絡,麻煩您留意信件內容。
    若您未收到郵件,請隨時告知我們。
    如有任何疑問,也歡迎隨時與我們聯繫,感謝您的協助!
  • 你好,我个人模型推理输出的时候,预处理结果有如下提示,是什么原因导致,算是错误吗?
  • 相關問題已另外有信件回覆,故關閉此討論串,若有其他問題可以直接信件中詢問,或另開新的討論篇章
