HDK SD BOOT
I'm using HDK V4.0.
I'm following the guide to boot from the SD card.
The following log appears and the device won't boot.
LOG:
NOTICE: BL2: v2.10.0 (release):v.1.5.0-leipzig
NOTICE: BL2: Built : 20:47:39, Nov 13 2025
ERROR: sd load failERROR: BL2: Image ID(4) load fail
ERROR: BL2: Failed to load image id 4 (-1)
It worked after I changed the SDK to 1.3.0.
Is SDK 1.4.1 not supported?
Hi TaeJung,
SDK 1.4.1 is supported, but for SDK later than 1.4.0, you will need to have OPTEE in your firmware to boot your KL730.
There's no such content in the guide.
Are there any new guides?
Hi TaeJung,
Yes, inside the SDK/01_BSP/01_Document/KL730_Development_Environment_User_Guide.pdf, in Section 8.5 SD Boot, it says that you will need the OP-TEE OS for your SD card.
Please refer to the above documentation for more information on SD Boot and OPTEE. Thank you!
I'm using an HDK board, so I only looked at the HDK board guide.
The HDK guide didn't cover this. Will it be updated in the future?
Hi TaeJung,
Thank you for your feedback. Yes, it will be updated in the future.
