How to rotate UI and Video image in 90 or 270 degree in KL730
Because the lcd panel only supports in portrait mode, I would like to rotate the image or video using the available API.
I've found that ISP module has rotation option, so I've tried using the API: VMF_ISP_Init , VMF_ISP_SetOption, VMF_ISP_Process. But the VMF_ISP_STATES_T.bFrameDone is always 0.
Meanwhile, Resize API works with no problem.
Is there any API that supports rotation in standalone way like independent of active video streaming?
Thanks in advance!
Hi Coben,
Regarding more in-depth questions on KL730, please contact your dedicated sales representative (the person you bought it from). They will coordinate with our technical team to assist you further. Thank you!
